Old 04-24-2014, 09:47 AM   #1
Adding Wingman to my antenna
I have the Winegard Sensar antenna on my Roo 19 and Camping World has a good sale on the Wingman right now so I thought I would add it. However looking at the way the antenna fold down it appears that the Wingman would end up between the antenna and the roof not allowing the antenna to fully retract.
It is hard to believe they would design the antenna this way. Am I missing something? I presume that the Winegard Sensar is fairly common with Forrest River so I am hoping that someone has done this before with a Roo or similar trailer.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 04-24-2014, 09:56 AM   #2
Oakman's Avatar
On my Silverback the antenna is too close to the bathroom skylight bubble to allow for the Wingman...bummer. I'd like to have a Wingman but I just do without.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-24-2014, 10:30 AM   #3
fonzie's Avatar
here is a picture of installation in this thread......mine is similar to this and is OK.
Wingman antenna
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-24-2014, 10:33 AM   #4
I added the wingman to our winegard and really couldn't tell that much difference. It wasn't that big of a deal to me anyway because watching tv isn't what I really want to do when I am camping. The bracket on my winegard broke some how and I just bought a new one with the wingman attached and threw the other one away. Probably should have given it away. Oh well, we'll see how the new one does.
OKI Marine is offline   Reply With Quote
Old 04-24-2014, 10:58 AM   #5
It lays flat. Check for about a foot of extra unobstructed roof clearance first.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-24-2014, 11:01 AM   #6
mark0224's Avatar
added one to our old trailer I did notice the difference that fade in and out of signal seemed to disappear. Wanted to move it to our new trailer but ac was in the way. the signal you receive here stinks 10 miles from tv tower and it still fades in and out.
mark0224 is offline   Reply With Quote
Old 04-24-2014, 11:29 AM   #7
Witch Doctor's Avatar
You need to get a jack, takes less room and you will get 3x's the stations. Clips right on after you take the bat wing garbage off. FR will soon be going to them......
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-24-2014, 11:56 AM   #8
As bad as I hate to say it, I agree 100% with Glenn, forget the batwing and replace it with the Jacks. Better all the way around, smaller, better, more channels, etc.
Old 04-24-2014, 01:43 PM   #9
Bryce's Avatar
The Jack's Antenna replacement head (put it on the old mast from the batwing) is on sale at campingworld.com for $38.21.
I just ordered one with a few other things I need to get.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 05-11-2014, 08:02 PM   #10
Bryce's Avatar
Finally got mine all on and working.
I had to replace the F-connectors on the coax from the Winegard booster/switch thingy and the base of the old Sensar antenna. Then replaced the coax from the base to the head of the mast. After that, no light on the Antenna but now getting 12vdc at the head. Rechecked everything then pulled it off and used a known good coax and the power supply and connections from the Antenna in the garage. Uh-oh... Still no light. DW ran it over to the local Camping World and they swapped it out. This one was good, but I still bench tested it before going back on the roof.
I just sort of pointed it towards Atlanta and set the a TV to auto program. First try, 14 channels! I never got anything at the house with the Sensar.
antenna
