Old 06-08-2014, 09:39 PM   #1
Exclamation Air condioner on Auto doesn't shut off
Hello, we are new to our FR sv-302. It is a 2008. We noticed that when we put the air on Auto it just runs and runs. It can be cooler outside (validated by temp guage) but it never shuts off. Is this normal operation for RV air conditioners? Thanks in advance.
katanajo is offline   Reply With Quote
Old 06-08-2014, 10:26 PM   #2
Mine did that too last night. I realized I didn't set the thermostat. Don't know if it would of made a differences or not.
Sent from my VK810 4G using Forest River Forums mobile app
nducker23 is offline   Reply With Quote
Old 06-08-2014, 10:56 PM   #3
Plain Old Member
Got any more details? Dometic Brisk Air, Coleman Mach? I'm assuming you have the analog thermostat? Regardless of outside temp, if it's hot inside, or the t-stat thinks it's hot inside, it'll run until it's satisfied. If it's an analog thermostat, it is possible that it's on the fritz. But, to answer the question, the AC should cycle on and off in auto mode. Have you tried bumping the temp up on the t-stat to attempt a forced shut off?
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
air conditioner
