Old 06-06-2015, 05:21 PM   #21
accumack's Avatar
Check the output temperature at the vent vs room temp there should be around a 20degree difference if not there is a problem with the unit. Mine is 22 degrees and can't keep up with the 2 units running full time. I don't think they ever test them in the heat.
accumack is offline   Reply With Quote
air conditioner
