11-13-2015, 05:15 PM
Air Conditioner Fan Runs Constant
Before all say check for auto control, let me say that my control unit does not have such feature. What is weird is that the furnace is controlled through the same unit and it cycles on and off as normal based on temperature. So, my question is, can I replace my control unit with on that has an auto setting and if so, and suggestions? Here is a pic of my existing unit.
11-13-2015, 05:24 PM
When on AC cycle through the on / off button bottom center. It should go from lo to high to auto them off. That's if I remembered correctly. When in auto mode fan will only run when compressor runs.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnebago Adventurer 38Q-26K Chassis...traded in 2015 Wildcat 282RKX
Towing 4 down 2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite or 2018 Colorado Crew Cab 4x4 V6 longbed
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
11-13-2015, 05:26 PM
Toy-aholic
what happens when you set it on fan & hit + 3 times? You're saying it only goes from low to high?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
11-13-2015, 05:35 PM
1)Turn it off.
2)Go to Fan, and change to auto.
3)Go to AC and pick hi or lo.
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
11-13-2015, 06:08 PM
Originally Posted by Hapy.Trainer
Before all say check for auto control, let me say that my control unit does not have such feature. What is weird is that the furnace is controlled through the same unit and it cycles on and off as normal based on temperature. So, my question is, can I replace my control unit with on that has an auto setting and if so, and suggestions? Here is a pic of my existing unit. Attachment 94224
See page 9 attached. Fan on Auto
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Had one just like it my R-Pod. It does have an auto setting. See post #2.
11-14-2015, 11:24 AM
Some of the "fast" answers above are not correct. See p. 3 and p. 11 of the instruction manual.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
11-14-2015, 11:26 AM
Love My Sunseeker
And, I always run the A/C on "low." I found running it on "high" blows fuses. Runs fine on "low."
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
11-14-2015, 12:53 PM
Fan running
This is easy you have 3settings turn to cool for ac turn to furnace for heat and fan if you want the fan to run all the time simple fix I hope
11-14-2015, 01:32 PM
I had a similar problem with mine. The fan ran continually but the AC never cycled on on low or auto, only on high. It took two trips back to the dealer to convince them there was something wrong. I even had to get the manual out and read it to them. They finally replaced the AC unit. Apparently Dometic had a bad lot of units but there was never a recall because it wasn't a safety issue. Good luck!
11-14-2015, 03:13 PM
Please also see this note on A/C on p. 9 which is inappropriately tucked in under the "Furnace" heading:
"Note: If additional indoor air circulation provided by the air conditioner is not desired during Furnace Mode of operation, select Au (AUTO) in the Fan Mode to shut the air conditioner fan off. If Lo (LOW) or Hi (HIGH) is selected the air conditioner fan will continue to operate on the selected speed."
The key words are "select AU **IN THE FAN MODE** " Select fan speed or AU setting IN THE FAN MODE before selecting A/C (or after if you wish to change then go back to A/C mode).
11-14-2015, 04:23 PM
Suppose he's still trying to figure it out?
11-14-2015, 05:56 PM
Originally Posted by Loraura
1)Turn it off.
Bingo-mine is the same way!
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
11-14-2015, 07:19 PM
Another adventure awaits!
Same one as ours ... Had to figure that out this summer ... See post from Loraura ... That's the way it works
11-15-2015, 10:39 AM
LOL so many interesting comments on this technical issue! 😅 Just curious to those who say you can change fan speed while in A/C mode - what button do you push? In the model we have the instructions for here that many of us have (SZLCD), if you press the Mode button again it will turn it off or to another mode, and if you push the +/- buttons that will change the temperature.
11-15-2015, 10:53 AM
To change the fan you go to
"Fan"
Then use the -/+ button till it says "AU".
11-15-2015, 11:06 AM
Good grief..............RTFM!
Semi retired now and enjoying it.
2013 F150 Super Cab 4x4, 3.5L ecoboost , 7700lb suspension package. 11,300 towing capacity and Max Tow package
2015 Flagstaff 8528IKWS Diamond
11-15-2015, 03:12 PM
aquaholic.
11-15-2015, 07:16 PM
"Fan"
That's what I said but others disagreed. Just curious how they are doing it. 😉
11-15-2015, 11:06 PM
Thanks all for the assistance. I will give it a try next time I have it out.
