Old 11-13-2015, 05:15 PM   #1
Air Conditioner Fan Runs Constant
Before all say check for auto control, let me say that my control unit does not have such feature. What is weird is that the furnace is controlled through the same unit and it cycles on and off as normal based on temperature. So, my question is, can I replace my control unit with on that has an auto setting and if so, and suggestions? Here is a pic of my existing unit. Click image for larger version
Name:	ImageUploadedByForest River Forums1447452942.428233.jpg
Hapy.Trainer is offline   Reply With Quote
Old 11-13-2015, 05:24 PM   #2
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
When on AC cycle through the on / off button bottom center. It should go from lo to high to auto them off. That's if I remembered correctly. When in auto mode fan will only run when compressor runs.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 FR Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 11-13-2015, 05:26 PM   #3
Toy-aholic
what happens when you set it on fan & hit + 3 times? You're saying it only goes from low to high?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 11-13-2015, 05:35 PM   #4
1)Turn it off.
2)Go to Fan, and change to auto.
3)Go to AC and pick hi or lo.
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 11-13-2015, 06:08 PM   #5
Flybob's Avatar
Originally Posted by Hapy.Trainer View Post
Before all say check for auto control, let me say that my control unit does not have such feature. What is weird is that the furnace is controlled through the same unit and it cycles on and off as normal based on temperature. So, my question is, can I replace my control unit with on that has an auto setting and if so, and suggestions? Here is a pic of my existing unit. Attachment 94224
See page 9 attached. Fan on Auto
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-13-2015, 06:08 PM   #6
Had one just like it my R-Pod. It does have an auto setting. See post #2.
Papa GLS is offline   Reply With Quote
Old 11-14-2015, 11:24 AM   #7
MNtraveler's Avatar
Some of the "fast" answers above are not correct. See p. 3 and p. 11 of the instruction manual.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-14-2015, 11:26 AM   #8
Love My Sunseeker
DXSMac's Avatar
And, I always run the A/C on "low." I found running it on "high" blows fuses. Runs fine on "low."
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 11-14-2015, 12:53 PM   #9
Boso's Avatar
Fan running
This is easy you have 3settings turn to cool for ac turn to furnace for heat and fan if you want the fan to run all the time simple fix I hope
Boso is offline   Reply With Quote
Old 11-14-2015, 01:32 PM   #10
Hoffwmn's Avatar
I had a similar problem with mine. The fan ran continually but the AC never cycled on on low or auto, only on high. It took two trips back to the dealer to convince them there was something wrong. I even had to get the manual out and read it to them. They finally replaced the AC unit. Apparently Dometic had a bad lot of units but there was never a recall because it wasn't a safety issue. Good luck!
Hoffwmn is offline   Reply With Quote
air conditioner, fan
