Air conditioner frozen up?
Fired up the a/c in my 2007 Rockwood the other afternoon and after an hour it had only cooled the TT from 89 degrees down to 87. Then the temp actually began to rise. Felt like a good cold flow at first. The flow stayed strong, but the coolness went down.
Thought maybe it had frozen up...but when I took the cover off in the cabin and looked as far up as I could with a flashlight I saw no signs of frost. Next thought was that a TT this old (which I just purchased six weeks ago) may have an a/c low on Freon. Or maybe the a/c is worn out and the whole unit needs replaced.
Went back this morning and it seemed to work fine. Cooled the TT from 81 degrees to 78 in 10-15 minutes. The unit cycled on and off a couple of times as it should once it reached the set temp.
So did it just freeze up on me and has thawed out now? Or do I have a more serious problem?
2007 Rockwood Signature Ultra Lite
