Old 08-20-2016, 05:28 PM   #1
air conditioner issue
Hi All
Our 2016 cherokee 274RK --- I set the thermostat to auto and choose the temp
more often than not it will run for 30 seconds ....shut off for 10 seconds and restart ....not good for the compressor .....once i tap on the thermostat it runs correctly for a good 5 hours then starts the on off thing again
Is this just a faulty dometic t stat ?
sameee is offline   Reply With Quote
Old 08-20-2016, 07:18 PM   #2
I had a similar issue. I changed out the thermostat and no joy. Turns out it was a board in the actual AC, and you'd need a proper diagnostic to determine that for sure.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
air conditioner
