Old 05-25-2014, 10:46 AM   #1
RedStick's Avatar
Air conditioner issue - we seem to be having difficulty keeping the air blowing cool.
The air will blow cool but after a while the air isn't cool any more. We aren't abusing the air conditioner by setting the thermostat on 70, etc.
That said when I turn off the a/c for a while to let it "rest" then started the air is nice and cool again.
Any tips? This doesn't seem normal to me. I had the shop look it over last year but of course they didn't experience the issue.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 05-25-2014, 10:55 AM   #2
Professional Texan
TexasBob's Avatar
Make sure the thermostat fan setting in on "Auto" not "high" or Low".
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-25-2014, 10:56 AM   #3
RedStick's Avatar
Thanks - it's on auto.
2012 F150 Ecoboost
Old 05-25-2014, 11:00 AM   #4
RedStick's Avatar
Correction - I haven't replaced the thermostat yet (upgrade). This is what I have... Click image for larger version
Name:	ImageUploadedByForest River Forums1401033522.934306.jpg
I have it on auto low... I think .
2012 F150 Ecoboost
Old 05-25-2014, 11:05 AM   #5
Ford Idaho's Avatar
Reset the thermostat to 75 and see what happens.
You could have it set to low and it is freezing up.
If it gets down to 75 then drop it to say 72 or 73 and then see.
Old 05-25-2014, 11:54 AM   #6
RedStick's Avatar
Thanks for the tips.
I reset before we headed to the pool and will report back. It was blowing cool air - set to 78 and auto-low on the fan.
It may be freezing up as you suggest.
2012 F150 Ecoboost
Old 05-25-2014, 02:09 PM   #7
Denver, CO
garbonz's Avatar
If it is ducted, you may help reduce freezing of the coils by leaving the outlet on the unit itself open to increase the airflow.
2017 Fuse 23T
Old 05-25-2014, 06:00 PM   #8
RedStick's Avatar
Don't know if placing the fan on auto-low did the trick, but when we returned after 90 or so minutes, things seemed to be ok.
We are taking the Roo back out in a few weeks - will see how she responds with that setting.
2012 F150 Ecoboost
Old 05-25-2014, 06:01 PM   #9
Infractee
Set too low?? No such thing.
If freezing up either condenser or evaporator coils are dirty/clogged or freon charge is low.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
RhoZeta is offline   Reply With Quote
Old 05-25-2014, 06:04 PM   #10
RedStick's Avatar
How often should the coils be cleaned? I've had the Roo for about 15 months. Perhaps the freon could use a charge. No idea.
2012 F150 Ecoboost
Old 05-26-2014, 03:42 AM   #11
Herk7769's Avatar
My "Rule of thumb"
Set thermostat 10 degrees below outside air temperature, but in no case lower than 90 degrees if it is over 100 outside. It will feel great because of the reduced humidity and will allow the compressor to cycle like its supposed to.
If the compressor runs constantly, it will ice up and reduce air flow.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-26-2014, 04:30 AM   #12
Retired Trucker/43 years
Noneyerbusiness's Avatar
I agree on humidity ... the coils will indeed freeze if it is "gawd awful" humid. Allow it to cycle by setting the temp a little higher with fan remaining on constantly
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 05-26-2014, 09:16 AM   #13
RedStick's Avatar
Thanks for the tips. If there is one thing that we have down here in Houston, it is humidity...and heat. It got to 90 degrees yesterday. The humidity was ok but it was there.
I'll give the ac a run through the next time we head out in a few weeks as we are home from our weekend trip. We sure love to camp!
2012 F150 Ecoboost
Old 05-27-2014, 04:26 PM   #14
Thurman's Avatar
IF you've had this unit for 15 months and have not cleaned the coils yet--I would highly suggest that you do so. Clean coils will make an A/C unit run much better whether the unit is on your camper or your home. Cleaning the coils of an RV A/C unit is not that hard. There are some good tutorials on Youtube and other sites.
Thurman is offline   Reply With Quote
Old 05-27-2014, 04:30 PM   #15
RedStick's Avatar
Thanks - I did some research on what I need to do and will knock it out before our next trip. I did take a look from the inside - all of that looked fine. I'll need to hop on the roof and knock that end out as well. Seems easy enough!
2012 F150 Ecoboost
Old 05-27-2014, 04:41 PM   #16
Witch Doctor's Avatar
Originally Posted by Herk7769 View Post
My "Rule of thumb"
That will never happen. You could set it at 75 and let it stay on. If your unit is freezing up your low on freon and wouldn't notice it at 80 but 100 yes. Thats because of the liquid in your condenser coil. When it changes states. from gas to liquid again.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-27-2014, 07:16 PM   #17
I took a trip to Crooked River S,P in S. Ga. this weekend past, and it was 95 degrees when we arrived at 3 30pm. I turned on the 13500 dometic ducted unit to high cool "on", but forgot to change it to auto, and after the next few hours, the ac felt a bit warm to me. Remembered the "auto" mistake, set it to auto and after about 45 min to 1 hour it was okay again. (it's set at 74) I think the coils were freezing up, but on auto, it turns on and off as needed, allowing the coils to defrost between cycles. Also, We had 2 Coleman popups before this V lite, and they would freeze up overnight almost every time set on low. I started running it on high, and turning the temp up some, so we didn't freeze, and that fixed the issue. Just some observations that I have made......Randy
Old 05-28-2014, 05:03 AM   #18
You are correct turning the indoor temp up at night and when the outside temp drops to 60 or below you could freeze your coil. The auto or on should not affect the compressor at all being it will still cycle in the on mode, that just keeps your fan blowing. which might even help from freezing the evaporator. You can only at best get a 15 degree diff. from the temp in the trailer to the output. As your units starts to cool down the supply air will also drop. So lets say your temp in the trailer was 80 degrees the a/c will be at about 65 coming out. The lower the trailer temp return air the cooler the air will be.
Coachmen M/H
Concord
2018 / 300 DSC
air conditioner
