Old 03-18-2015, 11:08 AM   #1
The pope's Avatar
Air conditioner normal?
I have one AC unit on the back roof of my 33 RETS-6. It is cooling but does not cool the inside down much. In 100% sun We are lucky if to see 80 inside when it 80 outside. It's dehumidifying / dripping some water. Is this the norm considering all the solar heating taking place. Curious what what others are experiencing. The air feels cooler but not cold. It must run thru alot of duct work in the ceiling.
The pope is offline   Reply With Quote
Old 03-18-2015, 11:17 AM   #2
geotex1's Avatar
Maybe normal, maybe not. You have a lot of camper to cool for a single unit, especially in full sunlight as you describe. You don't mention what air conditioner you have, but it's likely a Dometic model on a FR product. You can do a quick internet search for your model if you don't have the manuals and get the troubleshooting guide where there will be some performance checks (like temperature measurements) to see what's happening.
geotex1 is offline   Reply With Quote
Old 03-18-2015, 11:27 AM   #3
Oaklevel's Avatar
It is usually also normal to only get 10 degrees lower inside. In the hot sun.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-18-2015, 11:38 AM   #4
It your AC a 13.5K or 15K unit?
Old 03-18-2015, 11:52 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
We add a 13.5k AC to our 15k AC to keep things cooler.When we had 90+ temps we were lucky to get things under 80 with the 15k.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 03-18-2015, 12:01 PM   #6
Check the temp of the in-going air and the out going air.
Should be about 15 differences. If you are in direct sun you are sitting in a big box catching all the sun. My 30FT works fairly good until the outside temps reach 95 - Takes about an hour too cool down once air is started.
cadman99 is offline   Reply With Quote
Old 03-18-2015, 12:09 PM   #7
I did what Herk did to his AC and completely covered the cooling unit on the roof with the alum bubble insulation, insulated the piping with pipe insulation and taped the alum bubble insulation to the inside of the roof cover and have spent many days in full sunlight and 95+ heat and it cools our 8528RKWS just fine. TOWTA likes it @ 72 or cooler and it has no problem accomplishing it. We have a 13.5T unit.
Old 03-18-2015, 12:14 PM   #8
B and B's Avatar
OC, you have a white roof which helps. My Diamond tan colour sucks up the heat. The newer gelcoat are a champagne colour which assists with cooling.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 03-18-2015, 01:38 PM   #9
BamaBob's Avatar
Agreed! I also think the newer units are better insulated as well
We have a white roof as well (along with the gelcoat). Granted we have 2 A/C, but do not have any problems keeping the unit at 70-ish degrees during a 100 Alabama Summer day.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-18-2015, 01:58 PM   #10
B and B's Avatar
I am trying to convince the DW to install a second AC prior to going south, we were a little warm last year in Goshen.
air conditioner
