Old 04-14-2016, 08:26 PM   #1
Air conditioner problem?
2015 Primetime Avenger ATI:
It was 70 degrees today and I decided to run my AC as I have not used it all winter long and my rig sits in my driveway when not in use. I noticed the air from the vents didn't feel cool so I used a digital gauge and found this:
Inside temp of the rig was about 78-79, outside temp was 70. The air from the ac vent was blowing at 79. I flipped the stat to fan only, 79 degrees. Flipped to ac, 79 degrees. My progressive industries readout showed 4 amp draw with fan only and 7 amp with ac on. So the unit was pulling more power but the air was no colder. I set the stat down to the lowest temp and still no change. Let it run a good ten mins and still nothing. Any ideas? Freon perhaps? But is basically brand new, second owner. Thanks
rhino_160 is offline   Reply With Quote
Old 04-14-2016, 08:50 PM   #2
rracer5's Avatar
When you turn the thermostat down, do you hear the compressor kick in? If not, it could be anything from electronic issue to as you said low/no freon.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-14-2016, 09:41 PM   #3
I listened for that change from fan to compressor kicking and never heard it. Like I said, the amp draw changed from 4 to 7 amp on the digital readout so something was drawing more power somewhere. Anyone ?? Thanks
air conditioner
