Old 07-20-2019, 10:32 AM   #1
Air conditioner stops during the night
Air conditioner works well during the day but at night it stops (while I知 sleeping) and I need to turn it off for about 15 seconds. Upon turning it back on it runs fine. Any ideas?
rogerkathy is offline   Reply With Quote
Old 07-20-2019, 10:57 AM   #2
Ghost's?
MtBiker is offline   Reply With Quote
Old 07-20-2019, 04:41 PM   #3
Icing?
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-20-2019, 05:42 PM   #4
Maybe. Night temps get cooler so ice doesn’t melt as fast?
Old 07-21-2019, 12:32 PM   #5
If the outside temps become too low the AC is likely shutting itself down to protect it. On the other hand, if the outside temps are 60 or above you may need a tech to review it.
2015 Forest River Solera 24R
2009 Honda CRV Toad
lacamastraveler is offline   Reply With Quote
Old 07-21-2019, 12:36 PM   #6
Wolverine 1945's Avatar
Could it be reaching the temp you have it set @ ???
Do you relay want it running 24/7 ???
Wolverine 1945 is offline   Reply With Quote
Old 07-21-2019, 12:36 PM   #7
See Post #5 here:
AC quit working
You may have an ice sensor. May be your issue.
2011 Traverse LT, 3.6L, FWD
Old 07-21-2019, 12:47 PM   #8
Good info. I知 guessing the ice sensor is shutting down the conditioner because of the high humidity we have had and the lowering of temps. Only real issue I致e had is getting up during the night to turn it off for about 15 seconds the back on. Seems to fix it.
Old 07-22-2019, 12:46 AM   #9
I seldom use my AC, but I read somewhere that once an AC unit is turned off it needs a few minutes to equalize internal pressures before it should be started again or you're putting unnecessary strain upon the compressor. That makes sense to me, but it could be an old husband's tale too. Worth checking out.
metalsideup is offline   Reply With Quote
Old 07-22-2019, 08:32 AM   #10
Send a message via MSN to Tiggerdad
Could be icing or a sensor but 15 seconds is not enough time for a unit with ice to thaw.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 07-22-2019, 08:40 AM   #11
BandJCarm's Avatar
What he said........^^^^
But.....mine turns off at night, too. Good thing, or I'd freeze!
Sounds like it may be doing what it's supposed to. BUT.....is it turning off while it's still obviously hot in the trailer???? Is fan set to AUTO?
What kind of trailer? What kind of A/C unit?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-22-2019, 09:06 AM   #12
True. Called Short Cycling. From a Coleman-Mach O&M manual:
III. Short Cycling
When an air conditioner is in operation, its compressor
circulates refrigerant under high pressure. Once off, it will
take two to three minutes for this high pressure to equalize.
The air conditioning compressor is unable to start against high
pressure. Therefore, once the air conditioner is turned off, it is
important to leave it off for two to three minutes before
restarting.
Short cycling the compressor (or starting it before pressures
have equalized), will in some instances, kick the circuit
breaker or overload.
Old 07-22-2019, 09:26 AM   #13
AquaMan's Avatar
However, if the AC is already off and not functioning at the moment, turning the thermostat off and back on has no ill affect on the AC unit. Aside from that, Dometics have a built in delay.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-22-2019, 11:42 AM   #14
rlh1957's Avatar
Put in another quarter! LOL
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-22-2019, 06:32 PM   #15
The issue is air conditioner turns off at night when it is still warm inside the trailer. I wake up to no air conditioning and warmer temps in the trailer. Air conditioner is NOT running, is set at 73 on AUTO. Normally it comes on around 75-76 degrees but I awake to find it is about 78-80 and has not come on. I shut off the air conditioner for about 15 secs (remember, it is NOT running), turn it back on and it runs fine. Outside temps have been around 80 at night, 90-100 during the day. It is a Dometic and I have a 323 MK Wildcat 5th wheel.
Old 07-22-2019, 07:30 PM   #16
Try taking the fan out of AUTO and put it on Low or High, your choice. Keeps the air moving and evens out the temperature in the rig. Also, if it's an analog thermostat, that's probably your real problem. Dump it for a digital one. Keeps the set temperature much better.
Old 07-23-2019, 02:47 PM   #17
It is a digital thermostat. Good idea to try leaving fan on high instead of auto. I知 done for about 2 months but will keep this idea in mind.
air conditioner
