Old 07-04-2014, 10:09 AM   #41
I don't think insulation would help. The heat would still just be trapped inside of the cavity. I have now had several months to do other modifications and have fished wiring through the cupboards and through the floor for mood lighting inside and awning lighting outside.
Other thermostat solutions may be to relocate it. The end of the cabinet above the switch panel might work. You will have to extend the wiring there. The bottom of the cabinets is hollow, and there is a wire chase between the cabinets and the existing stereo/thermostat cavity. I have already fished that for my awning lights I put a pull string through it as it's no picnic to do.
There is also a floor cavity that can be fished to the other side of the camper. Also a lot of work. The fan solution seemed easy and still is working great.
Netcomdude is offline   Reply With Quote
Old 07-05-2014, 06:34 AM   #42
I placed a piece of closed cell foam behind thermostat. It sealed up the wire hole and also brought thermostat away from the wall half inch. I helped allot and the ac will now kick off. There is still a 3 or 4 deg difference cause that wall sure does conduct some heat. I may do some fans in that compartment if I ever have to remove the genesis. I can't get it to come out cause of the wire plug being on the side. I guess id remove that panel where u have fans installed just so i could unhook video cable. Thanks
cohuttariverrat is offline   Reply With Quote
Old 07-05-2014, 07:06 AM   #43
Witch Doctor's Avatar
Originally Posted by cohuttariverrat View Post
I know the thread is old but Im a new 2306 owner and having the same problem with thermostat not accurate because of heat from fridge. Has anyone came up with other solutions for this problem? I can't even get the genesis out because of where the wires plugged into. Would insulating this whole wall help? Any input would be helpfull before I tear the wall out. Thanks
The best way to get the stat from drawing heat from that area,(which is really stupid of FR) is to seal the whole with spray form where the wires comes through. Granted you are picking heat up from the refer but it is causing the higher temp all the time. If you blow air in that area it will throw the stat off more. A digital stat would not help, unless you got one with a remote sensor and wired it in. Honeywell makes one but it's pricey. When I was in HVAC we had false reading all the time due to the whole the wires came through. I would try that first. The temp of the wall should not make that much of a difference. I just keep shaking my head at what these engineers come up with. Also your 3 to 4 degrees is a little. I think the tolerance is 1 to 3 degrees.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-05-2014, 10:04 AM   #44
iluvlcy's Avatar
We drilled a pattern of holes around thermostat to let some heat out , also when we replaced with digital thermo the hole for the wires was huge so we covered it with duct tape and that kept a lot of heat from coming out onto thermo and it worked much better.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 08-06-2014, 07:05 AM   #45
So.... Can anyone recommend a replacement switch? A link or brand or part number?
Uncle Buck is offline   Reply With Quote
Old 08-06-2014, 08:04 PM   #46
Hello? Anyone?
Old 08-06-2014, 08:22 PM   #47
Hello? Anyone?
Old 08-06-2014, 11:10 PM   #48
Evereddie's Avatar
I don't think anyone knows what switch you are talking about.
Evereddie is offline   Reply With Quote
Old 08-07-2014, 06:46 PM   #49
Timex's Avatar
Is he talking about the ball bat switch for the hi/lo fan?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 08-10-2014, 07:48 AM   #50
The digital replacement switch for the A/C & heat (thread topic)
air conditioner, thermostat
