Old 07-12-2016, 10:35 AM   #11
Land of the Midnightsun
jjSpeedwagon's Avatar
Pull out plug when in need of extra ac , push back in when not needed
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-12-2016, 11:16 AM   #12
Forgot to mention I did order ac and inside vent system also eturnabond tape from Amazon delivered quick no damage or scratches. Was nervous but was fine
John & Janice
Old 07-12-2016, 08:26 PM   #13
Good job jj,, did you use the eterna bond in addition to the supplied seal? I plan to run my power cord out the floor and over to the left rear storage bin..and a hole out the bottom to run the plug out. I am trying to decide how to get the unit on top. I am 62 and may have trouble convincing me that I am 30!!!!!!Also found some extra storage space under the bed..!!! A big deal in this unit !!
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-12-2016, 08:35 PM   #14
One other tip tbonz I did today was I removed original ac inside vent ( main one ) and took rags and plugged duct work going to rear of Moho so all cool air is moving foward from that unit. Another huge difference. There is some air moving now threw 4 front ceiling vents and new bedroom ac covers plenty cold air in rear
John & Janice
Old 07-12-2016, 08:41 PM   #15
Yes absolutely use the eturnabond around vent opening. It will give seal on ac a very smooth surface. I was poking around YouTube and watch guy install ac on 5th wheel and I'm so glad I caught that or your seal from just ac on roof that has had caulk scraped off wouldn't be very good
John & Janice
Old 07-13-2016, 05:39 AM   #16
World Wide Wanderer
wahoonc's Avatar
Excellent!
I hope I don't have to do this mod, but at least someone has done it so we have an idea of what to follow. I actually keep a good sized roll of OMG EverSeal® - OMG Roofing Products on hand for work, so a few pieces find there way into my projects.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
air conditioner
