Old 07-01-2016, 06:19 PM   #1
Air Conditioners
Does anyone have any experience with ATWOOD air conditioners ??
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 07-04-2016, 02:18 PM   #2
Just go online and look at customer reviews from a few different sits. Not the best track record. But neither has Dometic lately.
hughd033 is offline   Reply With Quote
Old 07-04-2016, 02:47 PM   #3
Carknocker Family
Ida Ratherbe Camping's Avatar
Was looking to buy an Atwood, then saw that they were bought out by Dometic.
Nights camped 2014...26
Nights camped 2015...20
Nights camped 2016...20
2005 Dodge 2500 5.9 Cummins 6 speed manual
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-04-2016, 05:21 PM   #4
I have decided to go Dometic for the weight ,74 lbs. In the past I have had good luck with Dometic but things can change .
Old 07-12-2016, 09:57 AM   #5
Land of the Midnightsun
jjSpeedwagon's Avatar
Ac install 300 ds
HI tbonz and Aaron ( I know you'll see this to ) I got our 2nd ac installed over bedroom. Nerve racking because was in dark about how to run power to ac but good news you can run threw roof come down behind tv then on down behind droors . Pop out on top of water tank then go into large storage bend on side of Moho then out water drain hole. Then come out of the cap that is made to crank spare tire down with. But backing up to beginning. I went with dometic 13,500 btu low pro penguin II it matchies original ac. And ordered inside venting separate of course. Then a roll of eturnabond roofing tape. ( a must do not start with out it) 4" X 10' is perfect. I started on inside with vent pretty straight forward don't forget to pull screw out of crank handle then undo wires. Out it comes. Went up to roof. Was able to take out screws without scraping caulk of ( 104 temp outside so soft ) after all screws out took putty knife and cut vent loose from caulk. Vent came off no prob. Then very carefully scrape as much putty off roof as u can. ( don't tear roof but that is where eturnabond tape come in ) then laid down eturnabond tape around vent opening on roof , now u can see that front of vent cut out is somewhat open. There is a tunnel in styrofoam going to the right ( bedroom tv side ) good new. So I ran my electric cord threw tunnel and pulled back out for a measurement and I believe it goes all the way to wall. It seems straight so I held my breath and took hole saw and drilled 1 1/2 inch hole in roof behind tv And hit tunnel dead on. So for me that was the worst part. I drilled closer to tv staying away from the wall then drilled another hole behind tv working cord behind droors then pulled middle black pannel at bottom being able to see water tank drilled another hole missing tank then another hole into side storage Ben then noticed water drain hole in bottom of Ben I was home free. I went to lowes bought 2 heavy 15 amp 25' extension cords. Took one cut off end and ran it backwards back up to ac. Starting in the acces entry for the spare tire crank going up threw Ben drain and back up threw the holes I drilled. It worked out great. So now when using ac. I just open flap for spare tire crank pull out plug couple inches and use other drop cord I purchased to plug into power plug . It took me all day but it was 106 outside but the hardest part was getting ac on roof. Hope this helps I ran cord best I could to keep hidden. Might be other routs but found this way worked for me.
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 07-12-2016, 10:07 AM   #6
Inside vent off. Not bad wires unplug easy
John & Janice
Old 07-12-2016, 10:10 AM   #7
Outside vent off. Take time. Scrape putty off. EASY!
You can see wires in front of vent opening. Your tunnel is to the right. Other 3 sides r solid aluminum. Wood type sheets top and bottom. Foam about 5 inches thick
John & Janice
Old 07-12-2016, 10:16 AM   #8
Lay your eturnabond tape around opening and roll the crap out of it. When laying tape do not stretch it just lay it out. Super sticky. Will make nice seal to ac while water proofing all areas around vent opening.
John & Janice
Old 07-12-2016, 10:20 AM   #9
Then get it in your head your 30 yrs old and carry ac up ladder and gently set ac over vent hole
John & Janice
Old 07-12-2016, 10:32 AM   #10
Get your outside ac lined up over vent opening. Wire it up only. 3 wires. Put on inside base and cover. And your set. Sit back and wait for big smooth from wife. I got 2 !!!
John & Janice
air conditioner
