Old 06-03-2018, 07:00 AM   #21
Dutchmen Voltage. Unit has 3 A/C's. Two are direct and living room is vented (not as efficient as the direct dump units). 50 amp allows me to run all 3 at the same time. Awnings out as much as possible. Never had a problem in three years keeping cool.
Rusty
lcv800 is offline   Reply With Quote
Old 06-03-2018, 07:12 AM   #22
Don't forget outside maintenance on you A/C. Their purpose is to gather up the heat inside and dump it outside. If the coils and fins are clogged with dirt they can't dump the heat which brings down the efficiency of the unit and works it harder.
One other tip, if you don't have an surge suppressor/ems unit installed, get one, permanent or at the pedestal type. Not only will it protect your a/c unit(s) from surges and low voltage situations but also all the other sensitive electronics like your TVs and microwave.
2014 Sportscoach Cross Country, 361BH
jvalich is offline   Reply With Quote
Old 06-11-2018, 08:08 AM   #23
Grapelape's Avatar
Thanks everyone for the tips!
Chris
Grapelape is offline   Reply With Quote
air conditioner
