Old 04-08-2015, 03:10 PM   #11
Originally Posted by Toddupton View Post
It's all about the math. Heat loads, geographic locations, insulation and windows are just a few of the things that go into it. All these numbers are used to get a calculation to tonnage or BTU.
Thanks .. but I don't understand why I'm seeing such a wide range of btu's in similar sized rv's..
meganjoe is offline   Reply With Quote
Old 04-08-2015, 03:47 PM   #12
Location, location, location! Florida summers are different than Michigan. If you buy a trave trailer to use in Florida you would most likely need bigger ac than one for Michigan. For heat you need less in Florida than Michigan. So they can be built for more comfort on various locations.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-08-2015, 04:02 PM   #13
Witch Doctor's Avatar
You can not really have to much A/C with a travel trailer just by the construction and insulation. If you were going to size an A/C for a house you would be looking at 300 sq ft per ton. Trailer A/C are normally 13,000 to 15,000 Btu's. In Florida at that time of year the humidity is down. I would still get the biggest, and let the fan run and let the unit compressor cycle to your set temp.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
air conditioner
