Old 04-08-2015, 12:12 PM   #1
Air Conditioning
Hi,
We are looking for a new Travel Trailer in the 17 to 19 foot range. We have seen 5000, 8000, and 13.5 btu a/c units. How do we determine which size will work best?? We plan on being in Florida during Jan., Feb., and Mar.
Thanks, Joe
meganjoe is offline   Reply With Quote
Old 04-08-2015, 12:38 PM   #2
Ford Idaho's Avatar
IMHO as to air conditioning "bigger IS best" you can always throttle it back if it is too cool.
Get the most BTU's offered.
Old 04-08-2015, 12:41 PM   #3
LANShark42's Avatar
Unless you will be camping somewhere that it doesn't get very hot (or if heat doesn't bother you), it seems you would want the biggest AC available to you. Someone correct me if I'm wrong...
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 04-08-2015, 12:45 PM   #4
Broken Toe
Cowracer's Avatar
agree! nobody ever kicked themselves in the butt for getting too much A/C
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 04-08-2015, 12:54 PM   #5
Unless the OP plans on Boondocking
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-08-2015, 01:08 PM   #6
I guess I have to disagree with what everyone is saying. An AC unit that is oversized will not run enough to remove the humidity from the air. It will cool the air so fast that it will not have time to get the moisture out. It is better for AC to run longer to get the job done than to run too shut off before the job is done. Just my $.02
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 04-08-2015, 01:46 PM   #7
dieselguy's Avatar
Been there and still, have the T Shirt with a previous 24' TT. Sitting in Florida with a 5K or 8K A/C ... you'll kick yourself for not getting a 13.5K. Leave the fan on high and adjust the cool setting to your liking ... the coils won't freeze up that way. If you go auto and the fan speed adjusts to low ... it will tend to ice up the coils.
dieselguy is offline   Reply With Quote
Old 04-08-2015, 02:21 PM   #8
Nope, no boondocking planned.. We are looking at the Jayco 195RB, that and the Clipper 17fq both come with the 13.5.. We also like the Palomini 180fb but that only comes with a 5000.. Could the 5000 be swapped with an 8000??
Just wondering..
Thanks everybody for responding..
Joe
Old 04-08-2015, 02:29 PM   #9
I see what you're saying..
How do I figure out what size is correct??
Thanks, Joe
Old 04-08-2015, 02:46 PM   #10
It's all about the math. Heat loads, geographic locations, insulation and windows are just a few of the things that go into it. All these numbers are used to get a calculation to tonnage or BTU.
Old 04-08-2015, 03:10 PM   #11
Thanks .. but I don't understand why I'm seeing such a wide range of btu's in similar sized rv's..
Joe
Old 04-08-2015, 03:47 PM   #12
Location, location, location! Florida summers are different than Michigan. If you buy a trave trailer to use in Florida you would most likely need bigger ac than one for Michigan. For heat you need less in Florida than Michigan. So they can be built for more comfort on various locations.
Old 04-08-2015, 04:02 PM   #13
Witch Doctor's Avatar
Joe
You can not really have to much A/C with a travel trailer just by the construction and insulation. If you were going to size an A/C for a house you would be looking at 300 sq ft per ton. Trailer A/C are normally 13,000 to 15,000 Btu's. In Florida at that time of year the humidity is down. I would still get the biggest, and let the fan run and let the unit compressor cycle to your set temp.
Coachmen M/H
Concord
2018 / 300 DSC
air conditioner
