Old 03-06-2016, 05:25 PM   #11
W5CI's Avatar
If that will work I want one, my Honda 3000I Handi won't run the ac on my Cedar Creek when it cycles here in Arkansas ar 200 ft elevation and 90/100 degrees
2004 Cedar Creek 30RLBS MORryde IS/Disc Brakes
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29 2016 Days Camping 50
2017 Days Camping 8
W5CI is offline   Reply With Quote
Old 03-06-2016, 06:21 PM   #12
Thanks for the info vasnipe
booniey is offline   Reply With Quote
Old 03-06-2016, 06:57 PM   #13
Do you have to change the triac with a relay
twags is offline   Reply With Quote
Old 03-06-2016, 07:32 PM   #14
@ Garbonz - your post sounded as if you might have tried other capacitors before this one. If so, which ones? I just installed the Supco SPP6 and a fan delay @ 9 sec and did notice an improvement over stock setup. It was a simple 2 wire but would be interested if this one is even better (some mixed reviews on the internet about the SPP6). I'm running a Coleman-Mach 15k.
Thanks!
CraigBean7672 is offline   Reply With Quote
Old 03-07-2016, 08:18 AM   #15
Thanks!
I was looking at the 3T soft starter from MicroAir and on the installation there's a note that you have to change to a relay, do you have any info on that.
Terry
Old 03-07-2016, 09:00 AM   #16
Gadget
Cool gadget
ksmith954 is offline   Reply With Quote
Old 03-07-2016, 05:04 PM   #17
Denver, CO
garbonz's Avatar
Oh Boy Lots of good questions here, and I would mostly direct you to the Micro Air web site and their tech support.
I don't think you need anything other than the device they have that I mentioned which is rated for more than anything in the RV world. They are not exclusively an RV outfit but have a variety of applications so some of the information on relays and such are for complex devices.
I have a 9K BTU dometic, but I think this device will work on anything you got. I don't know if it will definitely work on a 15K RV AC with the honda 200i, since I havn't tested that, but I wouldn't be suprized if it did.
In my experiance the 2000i bogged down horribly (with a dometic hard start capacitor) if it started at all and with this device installed it barely came up out of eco mode. I should put my loop meter on the feed to see what it actually is drawing on start up, but it certainly is WAY less than the 2000i can handle, and remember I am at over 6000ft and running propane so I am depowered by 10% or more.
The wiring is 4 wires and replaces the PCTR and Start capacitor. Here is the specific wiring diagram they sent me based on the manual that I scaned and sent them. It was a piece of cake and took less than an hour.
Hope this answered some of your questions.
File Type: pdf Dometic Penguin EasyStart Wiring Diagram (2).pdf (143.7 KB, 164 views)
2007 Chevy 2500HD Classic LBZ Duramax/Allison (Stock)
2005 Bigfoot 1500C8.2 AWESOME
Old 03-07-2016, 05:04 PM   #18
Denver, CO
garbonz's Avatar
Originally Posted by Silverado2500HD View Post
Could you tell us what size A/C unit you are using this with? Also could tell a little more about wiring it?
I posted the answer in a separate post.
Old 03-07-2016, 05:10 PM   #19
Denver, CO
garbonz's Avatar
Originally Posted by lckeehne View Post
Can you send the YouTube link?
Here's the link: Most of the video is on the use of off grid solar and batteries for Air Conditioning, but they mention the soft start product, but they did not actually use try it yet.
Old 03-07-2016, 05:12 PM   #20
Denver, CO
garbonz's Avatar
Donno, but they will, give them a call or Email. They seem to stay up all night and answer questions.
