Old 06-03-2014, 09:41 AM   #1
psgrandpa1's Avatar
AIR CONDITIONING...water is not running to the side drain and running off the roof
TClick image for larger version
Name:	ImageUploadedByForest River Forums1401805911.546538.jpg
ID:	54225Click image for larger version
Name:	ImageUploadedByForest River Forums1401805938.160485.jpg
2012 GEORGETOWN 378
We have been plagued with water dripping from our under counter light. The overhead cabinet has a puddle of water on the bottom shelf. All is dry on top shelf...side walls, etc.
We had thought water was accumulating from rain on the awning...as when we roll in, there is a significant amount of runoff.
This am...we think ...it is the ac water standing on the roof... And not running off.
Our entire roof was replaced by Forest River last August.
FROGS are better problem solvers than most dealers....
Please send guidance as to what we should check before driving miles in the wrong direction to a certified dealer
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 06-03-2014, 09:51 AM   #2
psgrandpa1's Avatar
Name:	ImageUploadedByForest River Forums1401806945.564324.jpg
ID:	54234Click image for larger version
Name:	ImageUploadedByForest River Forums1401806973.227475.jpg
Added a couple more pics
Hollister MO
Retired 2011
Old 06-03-2014, 09:59 AM   #3
Ford Idaho's Avatar
Someone needs to get up on the roof and pull the AC cover and see if the screws are covered with Dicor as well as checking any drain holes or tubes.
Until then try tilting your unit to one side or front to back to help drainage.
Old 06-03-2014, 10:01 AM   #4
Assuming your AC is discharging the water to your roof properly, follow the water trail currently to find the entry point. Otherwise, pull the cover, run the unit and make sure the discharge tube is clear, allowing the water to flow out of the unit, with no backup, causing leakage at the mounting opening.
Old 06-03-2014, 03:32 PM   #5
MC9
You might pull the inside cover and make sure the hold down bolts in each corner are snugged up. Mine loosened up and rain dripped in briefly. There is a foam gasket on the roof that makes the seal.
MC9 is offline   Reply With Quote
Old 06-03-2014, 03:57 PM   #6
Herk7769's Avatar
OK, make sure your drain holes in the ac pan is free of debris that is blocking the holes and allowing the water to build up and enter the camper. 99% this is your problem.
The 1% is the air conditioner is not properly seated on its gasket.
"King Kong" the installer liked to tighten the unit down right to the roof. This crushes the foam gasket and causes the gasket in contact with the roof to "bow" actually reducing the gasket material in contact; not increasing it.
The units come with "Torque Tabs" (yellow in these photos) that are supposed to serve as a guide to allow even compression of the gasket without over crushing or unevenly compressing the gasket. You can see them if you drop the air handler or remove the filter.
Check yours as they are "supposed" to just touch the roof membrane when the gasket is properly and evenly compressed.
If yours are like these; DO NOT loosen them! You will leak immediately since the gasket is already ruined. The only way to repair an improperly installed gasket is to replace it and start over.
ID:	54266   Click image for larger version
ID:	54267   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-03-2014, 04:06 PM   #7
psgrandpa1's Avatar
Thanks for all the great tips. We will execute all of them until we find the problem,Click image for larger version
Name:	ImageUploadedByForest River Forums1401829554.452943.jpg
Having a great summer. Been out since March 20...
Hollister MO
Retired 2011
Old 06-03-2014, 08:04 PM   #8
VinceU's Avatar
Originally Posted by psgrandpa1 View Post
Thanks for all the great tips. We will execute all of them until we find the problem,Attachment 54269
One more place to check case it isn't the AC leaking at the roof.
The roof is "pebbled fiberglass" and has a short history of cracking in corners or along areas not installed flat with bulges. Since the water is showing closer to the edge of the roof than the crowned center it could be a crack or bad wall/ roof seam leaks.
Old 06-09-2014, 09:35 AM   #9
psgrandpa1's Avatar
Thanks all...
Hollister MO
Retired 2011
drain, roo, roof, water, air conditioner
