Old 08-03-2015, 05:16 AM   #1
Another ac question
We have a 15,000 btu unit on our vibe I have kinda of trouble shot it to maybe the thermostat it self just need to get a few options my ac works but won't kick off when it reaches the desired temp goes to fan mode . My thermostat domtic won't let me try and turn off the auto mode or dose it show its on auto everything else works on it function wise. ??????????
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 08-03-2015, 08:16 AM   #2
TURBS's Avatar
Picture of thermostat?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-03-2015, 08:39 AM   #3
clr
Need the model number or a picture like was stated. On my Domtic thermostat you use the mode to set it to AC then you use the fan button to scroll between auto, low, med or high. If set to one of the speeds low, med or high the fan will not turn off when the compressor is not running. In auto mode the fan should turn off a short while after the compressor shuts off. Hope this may be of some help.
clr is offline   Reply With Quote
Old 08-03-2015, 09:11 AM   #4
mud yapster's Avatar
To cold is better than not cold enough
Probably just the stat is acting up.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
