Originally Posted by Decon Blue
I've mounted a new King antenna on a 25' pole by my RV. It has its own 12volt booster that you can hook up in line behind tv then atatch the coaxle to it. I have a fully enclosed bottom on RV so Is there a way to hook coaxle to cable hookup on side of RV then go from cable hook up on Wall plate inside instead of running it through window ect. ?? Would that work ??
Does your RV have a cable input? As long as it is feeding the antenna, and not a cable system, the 12 volts will go down the coax and power the antenna.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
