Old 03-12-2014, 08:34 PM   #1
Question Antenna Ceiling Mount
I raised the tv antenna via the handle on the ceiling, didn't even change the direction - just raised it, and about 5 minutes later the whole handle assembly just fell off. Scared me half to death. The ceiling plate is still there. There is a directional face plate, a spring, a small plastic looking gasket and the handle that fell to the floor.
How do I put this back together and make sure it doesn't just fall off again? It almost hit my dog in the head. There are no screws or anything that I can tell that holds the thing together. There is a tiny set screw on the handle...is that what holds it up there?
2014 Rockwood 2304S
2011 Nissan Titan
jtintx is offline   Reply With Quote
Old 03-12-2014, 08:40 PM   #2
Yes that's all there is. Just make sure every thing is lined up.
DaveandSue is offline   Reply With Quote
Old 03-12-2014, 08:42 PM   #3
How do I keep it from falling back off? Just the set screw?
2014 Rockwood 2304S
2011 Nissan Titan
Old 03-12-2014, 08:48 PM   #4
Evereddie's Avatar
Maybe it wasn't as tight as it should be and vibrated off with all of the vibration while traveling. Use a little locktite compound on it.
Evereddie is offline   Reply With Quote
Old 03-12-2014, 08:53 PM   #5
Does the spring go in first up into the ceilng or outside against the handle?
2014 Rockwood 2304S
2011 Nissan Titan
Old 03-12-2014, 09:07 PM   #6
Ok, found the manual...spring does not go up into the celing...just in case anyone else has this issue.
Thanks for the help everyone.
2014 Rockwood 2304S
2011 Nissan Titan
Old 03-12-2014, 09:10 PM   #7
Average Joe
MrJoe's Avatar
Sorry for the hijack, is this how you would take it apart to lube it?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-12-2014, 09:28 PM   #8
The set screw is what holds everything up so just remove it if you want to take it down. I didn't feel anything "greasy" so I don't know what to lube.
2014 Rockwood 2304S
2011 Nissan Titan
Old 03-12-2014, 09:30 PM   #9
Average Joe
MrJoe's Avatar
From what I've read, I think you apply dry silicone to the washer.
Joe and Karen
Old 03-13-2014, 08:25 AM   #10
Fulltime family RVer
Do you happen to have a link to the manual?
antenna, mount
