Old 06-24-2015, 12:03 AM   #1
Antenna signal weak
Hi,
On my 2010 tracer 3000bhd there is a stationary antenna (doesn't have the option for the directional antenna).
The reception is brutal. I was told that the switch that can be changed from cable to air or to off can be the problem. I switch it to air and still the same issue however I did notice that when I select Air or cable the light doesn't come on. I checked the fuse, and its good.
Is there something wrong with this switch? Is it an actual booster? I'm not sure.
Any advice would be greatly appreciated.
Thanks.
Frost is offline   Reply With Quote
antenna
