Old 09-17-2015, 07:58 PM   #1
Who Dares, Wins
doc73's Avatar
Any one use an air filter in their RV?
I was doing some work on the Grey Wolf and checked the A/C filter. It was clogged again, just cleaned it a few weeks ago and only was out for one weekend. We do have a cat but man it sure does clog fast... Any one use a small home or office air filter to keep the environment a bit less dusty?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 09-17-2015, 09:53 PM   #2
Yes -- we use one in the bedroom. It also doubles as a source of "white noise" at night.
bruceatlam is offline   Reply With Quote
Old 09-18-2015, 08:18 PM   #3
Who Dares, Wins
doc73's Avatar
Is there a model you recommend? Not sure where to start...
2015 ChevyHD D-Max
Old 09-18-2015, 09:20 PM   #4
No, I don't have any particular recommendation. I would make sure that it's a HEPA filter. After that, it needs to fit the space ---- both in filtering volume capability as well as physically. Its size has to fit where you want to put it.
Old 09-19-2015, 03:03 PM   #5
ben31's Avatar
I buy the filtrete filters and cut them to size. It helps get rid of the allergens in the TT.
Works very well for us. Of course, you will need to replace the material every few weeks, but one filter, when cut, can last 2-3 changings (with each piece lasting abou 3-4 weeks).
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 09-19-2015, 03:27 PM   #6
[QUOTE=ben31;988061]I buy the filtrete filters and cut them to size. It helps get rid of the allergens in the TT.
Works very well for us. Of course, you will need to replace the material every few weeks, but one filter, when cut, can last 2-3 changings (with each piece lasting abou 3-4 weeks).[/Q
So you place the cut material inplace of the foam filter on the A/C?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-19-2015, 04:45 PM   #7
bend302's Avatar
We picked up an air filter (hepa) at Best Buy and run it 24/7 while in FL. They have some pollen down there that drives us crazy. But the filter solved that issue.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-19-2015, 11:01 PM   #8
Dahagen
I use a Honeywell HPA060. Less than $100 and works great but only on AC power.
dahagen is offline   Reply With Quote
Old 09-20-2015, 11:01 AM   #9
ben31's Avatar
I put some wire behind, to hold the cut pieces in place of the foam.
Ben and Doreen
Old 09-21-2015, 04:12 PM   #10
Cornelius's Avatar
I use a Honeywell HPA-200 in my Georgetown.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
