Old 08-22-2015, 03:12 PM   #1
Any way to adjust fridge and freezer temp. separately?
Just got back from a 3 day camping trip. The fridge temp. was perfect at 40 degrees but the freezer stayed at 10 degrees, which should be at 0. Is there any way to adjust the freezer temp. without making the fridge too cold?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 08-22-2015, 03:41 PM   #2
Your typical RV absorption fridge freezer temp should be aprox. 30 degress less than the fridge section. I would say yours is operating properly.
No, you can not adjust the fridge temp and freezer temp seperately.
Your typical residential fridge freezer is normally around 0 degrees.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 08-22-2015, 03:43 PM   #3
Georgia Rally Coordinator
aceinspp's Avatar
Mine will vary between 10 to 0. So I'm happy. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 12
Old 08-22-2015, 04:54 PM   #4
10 or 0, either will work fine. Ours hardly ever makes it to zero, usually between 5 and 15. I just looked at the high low temps, reset a couple of days ago, and it has ranged from 6-14. Even 15 keeps our stuff frozen just fine.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-22-2015, 08:28 PM   #5
The only things I had in the freezer for this trip was a bag of ice and ice cream. The ice was fine but the ice cream was very soft. I guess I will just have to get used to eating my ice cream that way Thanks for the info, everyone.
2011 MicroLite 23LB
Old 08-23-2015, 11:37 AM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Zinger.....the thermostat slide types are pretty ineffective. Set it to the coldest spot. These temps you have are within range. I myself have a D-cell Camco fan in the refrigerator AND freezer compartments. It helps to circulate the air. My temps pretty much stay at 4 and 32. Once in a blue moon I'll see a mild piece of ice in a liquid in the fridge,,,,but it hasn't been a problem. Being as I was in the refrigeration business, residential AND commercial, for 40 years, I've tried several things,,,,,what I've done is the best with what these babies will do. I highly recommend the fans. The D cells last about a month and then you have to replace them. Booddocking said it right about not being able to separately control or modify the two temps.
Grampa Jim is offline   Reply With Quote
Old 08-23-2015, 11:56 AM   #7
Jim, Do you put the fans in the refrigerator where your food is and if so where do you put them top or bottom? ? Thanks Cyndi
CLewis is offline   Reply With Quote
Old 08-23-2015, 12:06 PM   #8
Cyndi.....anywhere in the fridge does a good job of circulating the air and keeping hot and cold spots mixed to a good temp for anywhere in the fridge. One thing,,,,make sure you defrost those coils every once in a while. When the coils are solid ice, you've let it go too far and that'll affect the cooling process. You also need to defrost the freezer at the same time. A hair dryer does a good fast job.
Old 08-23-2015, 12:10 PM   #9
aceinspp's Avatar
X2 with the fans. Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 12
Old 08-23-2015, 12:18 PM   #10
Being that we're camping here in Missouri, ours recently defrosted on its' own and we had water in the bottom bins. Is this normal. My wife thinks there's an auto mode for this, but I doubt it. Other than that, the frig and freezer seems fine.
gfarmcafe is offline   Reply With Quote
fridge
