Old 08-12-2019, 05:22 PM   #1
rickj514's Avatar
Anybody replaced their 110-volt AC TV with 12-volt DC unit?
Hi Everyone,
Fairly new to this great forum. My wife and I recently purchased a Flagstaff MicroLite 25FBLS, which is the same trailer as the Rockwood 2511S. We've only used the trailer once so far for about 5 days and are very excited about it. We have another trip planned right after Labor Day.
We do mostly dry camping so we’re generally not connected to 110 volt AC power. Since I enjoy watching a movie in the evenings, I plan on replacing the 110-volt AC powered Furion 32" TV that came in the trailer with one that runs on 12 volts. In this trailer the TV is located next to the kitchen and above some cabinets (See attached pictures). The TV swings out so you can store things behind it. There’s an IRV Technologies AM/FM/DVD player which is in the cabinet below the TV which runs on 12 volts, so I’m hoping to tap into its DC power source.
There are plenty of 12-volt TVs on the market with the identical dimensions. If I can get to the power and bring it up to where the TV is I should be able to watch DVD movies off the batter(ies) just by replacing the TV.
Has anyone done this? I’m guessing that the easiest way would be to get it at the back of the AM/FM/DVD player, but I'd like to hear about anybody else's experience that has already done this.
I also plan on putting a smaller 12-volt TV in the bedroom, but I have no idea where I can find a 12 volt source!
Thanks in advance!
Rick
** I did post this question on a thread for the Rockwood 2511S.
ID:	212194   Click image for larger version
Rick & Marilyn
TT - 2019.5 Flagstaff MicroLite 25FBLS
TV - 2019 Ram 1500 Laramie 4X4
rickj514 is offline   Reply With Quote
Old 08-12-2019, 05:32 PM   #2
Flybob's Avatar
The choice for 12V tvs is limited and they tend to be more expensive. Many people simply add a small inverter to drive the tv. You can pick up a 300W ( more than enough) pure sine wave inverter for around $50 almost anywhere.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-12-2019, 06:18 PM   #3
bikendan's Avatar
THIS^^^^^
Bought a refurbished Vizio 110v smart tv for $50 and a 150w inverter for $12.
Way less than a comparable 12v tv.
And I can use the inverter's USB charging ports for electronic devices.
Equalizer WDH
Old 08-12-2019, 06:54 PM   #4
rickj514's Avatar
Thanks, Bob.
I realize that I can run the existing 110-volt AC TV from a 12-volt source by using an inverter, but it will use up far more current than getting the 12 volts straight from the battery (OHMs law). It's worth thinking about though, and I do need to look at that closer and see how much more current I would use that way.
I think a 12-volt 32" TV will run me about $299. Certainly more than the cost of an inverter.
I'd still have to find a 12-volt source though.
BTW, thank you for your service!
Rick
Rick & Marilyn
Old 08-12-2019, 07:15 PM   #5
onetonford's Avatar
I found a 22 inch Vizio at Costco it was a 110v unit with a power supply and I wasn't really interested in buying a 12v but while browsing around with my wife shopping I saw this TV on sale for less than 200 dollars and I spun the display around and checked the power in and it said 12v DC so I bought it and made a power cord for it. and now it resides in my fivers bedroom. I also like the fact it is LED and not backlit so it uses less power and runs cooler then my inverter uses for the 32 inch in the living room.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-12-2019, 07:16 PM   #6
bikendan's Avatar
Is there a 12v dc smart tv?
Equalizer WDH
Old 08-12-2019, 07:35 PM   #7
onetonford's Avatar
all the ones I have looked at are 17v DC for some reason? the tv I bought they had the same model that was smart but the volts were 17 so I bought the dumb one.
2011 25 RL Wildcat
Old 08-12-2019, 08:11 PM   #8
rickj514's Avatar
Good deal! I wonder if there's a higher chance of failure putting an LED TV in an RV that is not designed to me "mobile". At lest at Costco you're protected for 2 years. I think I'll look at our local Costco and see what they have.
Rick & Marilyn
Old 08-13-2019, 04:48 AM   #9
jd50i's Avatar
You don't need a special 12V TV, I purchased 2 Samsungs and put in my TT, both were 12v already with a 110v power supply. I just needed a plug for the 12v.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-13-2019, 12:57 PM   #10
This is true. I believe Sony does the same thing. As far as travelling with a "home TV", there should be no more problems that an RV. Just make sure that the conversion is from 115V ac to 12 volts dc and not an odd dc voltage. Those should be in the specs or on the power supply.
PenJoe is online now   Reply With Quote
