Old 03-01-2016, 09:13 PM   #31
mike.t's Avatar
Well safe trip and happy travels/camping.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-01-2016, 10:05 PM   #32
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Thank you, Mike.
Grampa Jim is offline   Reply With Quote
Old 03-01-2016, 10:21 PM   #33
Members
Tommy Joann's Avatar
Originally Posted by n0ms View Post
During the normal process, moisture is removed from the air and items in the refer. The fan motor inside the residential refer runs when the compressor is on. Apx 3 times in 24 hours, heaters come on in the freezer part to melt the frost build up on the coils that get cold. The water leaves the unit thru a drain. If the moisture were trapped in the refer or freezer part, with the unit not running, the fan motor could rust. I've seen this maybe 2 times since 1977.
Short answer, leave the doors cracked open when in storage.
I am a retired lead maintenance mechanic and for 30 years worked on large air handlers, chillers, condenser fans, evaporator fans, window a/c's, freezers, refridgerators, ice makers, humidifiers, etc. Never ever have seen one rust!
2018 Salem 28RLDS Showstopper Package
2015 Chevy Silverado Crew Cab LT Sport
Husky Centerline WDH
Tommy Joann is offline   Reply With Quote
Old 03-02-2016, 10:21 AM   #34
Tommy,,,,,,I also, for 40 years, did the same career line that you did. And I fully agree with what you said. OK,,,,all you folks out there.....two of us are giving you bunches of info that's not wrong.
