Old 12-16-2018, 08:20 AM   #1
Atwood Furnace won’t ignite
So we woke up to a very chilly RV today in PA. The furnace starts the blower but will not light. After about 90 seconds the blower shuts off and nothing. Any ideas???
skicielinski is offline   Reply With Quote
Old 12-16-2018, 09:01 AM   #2
koller1509's Avatar
Did you run out of propane?? If so it will lockout the system after several failed attempts to ignite. Try lighting your stove to make sure you have no air in the lines. Locate the 12 volt fuse for the furnace and pull it for 30 seconds. Turn off the thermostat and reinsert the fuse. Turn on the thermostat and see if that helps.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is online now   Reply With Quote
Old 12-16-2018, 09:23 AM   #3
See above post. If that does not work check to make sure exhaust port is not plugged/blocked.
Kimber45 is online now   Reply With Quote
furnace
