Might anyone have a part number or source for the plastic insert that slides over the orifice valve for the front center burner of the Atwood cook top?
the model number is R-V 2135BBP.
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
A few years ago that plastic part melted on my center burner. I contacted Atwood customer service and explained what happened and they sent me out replacements free. They said it probably happened because the burner was pushed out to test the propane pressure at the factory instead of taking the time to unscrew it. Sure enough the burner bracket needed to be bent a little to make it line up correctly. No further problems with the plastic bushings after that.
