Old 05-14-2015, 10:12 PM   #1
Auto scan on Furrion TV
I am set up in a campground that I have been at before but this time when I run auto scan on the tv all I get is 7 stations and only one is a local main station (CBS). Can't get the local ABC or NBC. Had no problem last time I was here. I'm getting the signal over the air. Anyone have suggestions? The manual isn't much help.
Ncgrandma is offline   Reply With Quote
Old 05-14-2015, 10:18 PM   #2
Blog: RVroadtripper.com
hbillsmith's Avatar
I have seen this issue on my 2016 Wildcat. In the bedroom is a wallplate that has the antennae amp switch. If you remove that plate behind it you will find your amp and all the coax and splitters. Some of your connection are loose and need to be reseated or twisrted on.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-14-2015, 10:19 PM   #3
Boso's Avatar
Adjust your antenna
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 05-15-2015, 02:10 AM   #4
RooVader's Avatar
It is amazing what even small turns of the antenna dial can do. You might have to try it a few different settings to get the best signal.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 05-15-2015, 06:46 AM   #5
thanks for the help. I turned the direction of the antenna and tried scanning again. What a difference. Ended up with 17 channels including all the locals. It's great when something so simple works.
Old 05-15-2015, 06:53 AM   #6
Oakman's Avatar
Turning the antenna becomes more critical the farther you are from the television transmitters. I have an app on my smartphone that shows which direction the TV signal is coming from and the signal's strength.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-15-2015, 12:00 PM   #7
Maris's Avatar
Oakman - What is the name of the app. that you have?
Maris is offline   Reply With Quote
Old 05-15-2015, 12:23 PM   #8
Oakman's Avatar
It's an app for android phones called TV Antenna Helper. There is also one called Antenna Pointer, both are free.
I'm sure there must be something similar for IPhones.
Bob and Joyce
ATU Local 788
Old 05-15-2015, 01:20 PM   #9
Make sure the antenna booster is on
davidinstlouis is offline   Reply With Quote
Old 05-15-2015, 01:29 PM   #10
StlClay
Winegard makes a replacement amplifier that includes a digital signal finder. Available through Camping World and Amazon. Fits in the same opening that you have now. About $80? Amazon.com: Winegard RFL-342 SensarPro White TV Signal Strength Meter: Automotive
Stlcaly is offline   Reply With Quote
