Old 11-15-2013, 02:53 AM   #11
Just a member
kandl's Avatar
Originally Posted by cdnwillyg View Post
We have the supplied barbeque that came with our 2014 5th wheel that attaches to the rail on the siding. I have concerns about the heat that is subjected to the trailer siding. Has anyone experienced any distortion or other issues from this set up. We are using it on a separate table now but would like to use it on this rail setup.
Echo the comments thus far - we've put ours through the ringer for three seasons with no issues. Lots of burgers, steaks etc and although the side of the TT gets a little warmish, it's not so much so as to get raise some hairs. There's a warning too related to the use of the RVQs to not fire them up under the awning. Umm... we done that too (rain) on a number of occasions - no worries. The caveat is that you stand by your cooking apparatus and closely monitor the operation during the production of succulence.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 11-15-2013, 06:57 AM   #12
I had one and it didn't cause any problems other than, as somebody already said, the smoke getting into the trailer via an open window. I had a rack that the BBQ hung off of and it came with the BBQ. If it's the same style as the one I had then you could take it( the rack) off the wall and set it up on a table next to the trailer. Mine was under the awning and there was never a problem with that either but be vigilant. Just like the one in the above post by Kandl.
Pipeman is offline   Reply With Quote
Old 11-15-2013, 07:03 AM   #13
TURBS's Avatar
Good point I forgot to mention bracket can be turned so grill can be used on a table top as well as hung on the side of camper.
Old 11-15-2013, 07:07 AM   #14
TURBS's Avatar
Op is this yours?
If so turn the hanginging bracket on its back"where it would mount on camper"
Then set your grill on the now vertical pipes via the second "t" mount on grill.
Old 11-15-2013, 03:04 PM   #15
bikendan's Avatar
without knowing which grill you're talking about, it's not easy to say.
most FR products come with the Sidekick grill, NOT the RVQ. many call theirs an RVQ but FR hasn't supplied those since before 2005.
and are you using the supplied bracket correctly?
we've been using ours for the past 7 years and NEVER had any issues.
is it the best BBQ grill, NO! but it works quite well for dogs, chicken, burgers and most smaller grill items.
the side of our trailer never gets as hot as it does sitting in the summer sun for hours!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-15-2013, 09:37 PM   #16
Just a member
kandl's Avatar
Concur but FR adds to the confusion by continuing to refer to the outdooe gas grill arrangement as "RVQUE" in their brochures. Many simply abbreviate to RVQ. From the 2011 Rockwood brochure - same for 12 and 13
Old 11-15-2013, 09:50 PM   #17
TURBS's Avatar
Yep
Old 11-16-2013, 01:11 PM   #18
trudinator's Avatar
Works great for fresh pizza too! Just put on low, slide your fresh crust on the grate for about 3 minutes, pull it off, flip it over, put your toppings on and return to the grill for about 10 minutes until cheese is bubbly and brown. Yum! Of course, works bettrr with a Round Barn Woodcrafts pizza peel. Insert shameless plug here. LOL
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 12-02-2013, 06:29 PM   #19
HONDAMAN174's Avatar
So then here is a question... My new RV doesn't have the rail on the side but does have a propane connection. Should I let the dealer install a rail for me, do it myself, or not do it at all since it didn't come with it. I have an extra sidekick that I bought a few months back.
Just glad to get away
Old 12-02-2013, 06:38 PM   #20
Regardless of who does it, MAKE SURE they put a backer board inside to screw/bolt thru. Otherwise it will be coming loose or coming off. The factory mounted rail on our 08Flagstaff 831RLSS came loose the 1st time we used it. Dealer put longer, bigger stainless bolts/nuts thru a backer board and it never came loose again. Our 12Flagstaff 8528RKWS has longer screws into a backer board.
