Old 07-06-2019, 07:08 AM   #1
Bathroom Fan - When to run?
Maybe a dumb question but here goes...
Do you run your bathroom fan all the time or just when you are actually in the bathroom?
Why?
Does anyone do this in effort to avoid over-sensitive LP alarming?
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 07-06-2019, 07:14 AM   #2
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
We generally ONLY run ours while we are showering - to remove the moisture from the room. As soon as we get out of the shower and dry off as we leave the bathroom, we turn the vent fan off.
Running it all time (especially here in Texas with our heat) would basically defeat the air conditioners by pulling all the cold air out, probably faster than the A/C units can put it in.
You especially don't want to have that vent fan running when you flush the toilet - otherwise it will pull the black-tank smells into the trailer.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 59
rjshiflet is offline   Reply With Quote
Old 07-06-2019, 07:26 AM   #3
Canadian Member
We run ours all the time except:
1) when flushing the toilet
2) when the AC is on
When taking a shower its always on, AC running or not. The Maxxair fan in the bathroom moves a lot of air if you have the windows open in another room. From our hybrid TT days we’ve found that moving air in a camper is important to control condensation.
We never boondock so those who do may be concerned about using up battery capacity.
2019 Rockwood Signature 8290BS
Old 07-06-2019, 08:26 AM   #4
Only run it when DW uses the toilet. I don't need it because my stuff doesn't stink.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-06-2019, 09:04 AM   #5
nomad297's Avatar
I don't run my bathroom fan all of the time, but I always run it when the shower is being used, and for a while afterwards to evacuate as much moisture from the camper as possible. On the rare occasion that I am cooking inside, I will open the roof vent closest to the kitchen and run the bathroom fan. I will usually leave it running on its lowest setting at night while we are sleeping because if one of the dogs fart, and it is not running, the LP detector will go off. I forgot to do this last night and was awoken at 2:34 this morning. I reset the LP detector, turned the fan on and went back to bed — no more alarms sounding. The fan is also running whenever somebody is taking a dump and it usually ends-up being left on because somebody forgot to turn it off. It seems to be my job to monitor this and turn it off when it is left on by mistake.
When the fan is left on, there is a very noticeable difference in how well the air conditioning and heating is doing its job, especially when the fan is sucking air out at its top speed.
Many people warn you not to flush the toilet with the fan running, but I have never noticed an odor problem doing this because it must get sucked out faster than it can linger with my fan.
Bruce
Old 07-06-2019, 02:33 PM   #6
CGK
If the A/C or heat is on, we typically run the bathroom (MaxxAir Ventilation) fan during showers or AFTER the toilet is flushed to clear any odors from the room without drawing them from the black water tank. On occasion, we do run the fan briefly to eliminate false alarms (e.g., while cooking, if the meal of the moment is causing the smoke detector to sound). If neither the heat nor the A/C is on, we sometimes run the fan for a short while just to bring fresh air into the TT.
CGK
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS
CGK is offline   Reply With Quote
Old 07-06-2019, 02:35 PM   #7
bikendan's Avatar
Only when showering.
Equalizer WDH
Old 07-06-2019, 02:37 PM   #8
I run it when i need it . either to exhaust a stink bomb or to draw in cooler air from outside . when i don't need it i don't run it
MR.M is offline   Reply With Quote
Old 07-06-2019, 07:53 PM   #9
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 07-06-2019, 07:54 PM   #10
WOW didn't know there was someone as perfect as me!
Ha Ha just kidding everyone.
jdkbrooks is offline   Reply With Quote
bathroom, fan, roo
