Old 07-23-2016, 06:00 PM   #1
Battery Check Your Devices
Just a friendly reminder to gather up all your battery powered gadgets & devices tomorrow and give their battery compartment a quick visit eyeball check. My TV remote is only a year old yet it quit working today. A simple battery change, so I thought, but it turns out one of the batteries started leaking. That leaking substance is corrosive, and can lead to a destroyed device in short order. I subsequently did a check on my other gadgets and found 2 other leaking batteries inside a flashlight and a walkie-talkie I keep in my glove box. Just thought I'd pass on some advice to add "checking on the batteries on our "little-er" gadgets that we take for granted" on the list of routine maintenance.
And at the sake of sounding redundant, it's also a good time to take account of the various types of batteries your gadgets have and write down on your to-do list to pick-up all the spares you need for backups to them devices... little devices that play a big role in our RVing lifestyle.
metalsideup is offline   Reply With Quote
Old 07-23-2016, 06:25 PM   #2
Good reminder!
That is something that I think the majority of us never think about.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is online now   Reply With Quote
Old 07-23-2016, 06:31 PM   #3
northstar1960's Avatar
I change my batteries when ever the items quit working . i walk over to the battery drawer pull out the correct ones
close the battery drawer then replace the old ones which i toss in the trash can
northstar1960 is offline   Reply With Quote
Old 07-23-2016, 06:35 PM   #4
f5moab's Avatar
Except for the smoke and CO2 detectors, that is exactly what I do, and cannot remember the last time I have had a battery leak. But I only use Duracell, Energizer or Ray-O-Vac batteries
f5moab is offline   Reply With Quote
Old 07-23-2016, 09:00 PM   #5
X2 on the smoke alarms. they always go bad at 3am
Old 07-24-2016, 12:19 PM   #6
I remove all the batteries when I'm not using the RV, don't mix old batteries with new ones and don't mix different brands in the same device. That can cause them to leak.
edcronin01 is offline   Reply With Quote
Old 07-24-2016, 12:40 PM   #7
Thanks for the head's up. I only take my batteries out of my devices at the end of the season.
However, I take ALL my gadgets with batteries out of the RV EVERY time we unpack after each camping trip. My camper is stored outside in the heat--which is hard on the batteries. (and yes, sometimes I miss one!).
brewjaz is offline   Reply With Quote
Old 07-24-2016, 03:25 PM   #8
Carbon zinc batteries leak acid that eats away the metal contacts of the battery case. Alkaline cells, when they leak, make a mess but rarely destroy the battery contacts.
If an alkaline cell leaks into the battery compartment, scrape away all of the white stuff you can with a toothpick then press a paper towel that's wet with vinegar into the area. If you listen carefully, you'll hear the vinegar reacting with the alkaline deposits left. When the crackling noise stops, wipe everything down with a water dampened towel and your battery box should be good to go again.
Phil
pmsherman is offline   Reply With Quote
Old 07-24-2016, 05:49 PM   #9
Battery Check your Devices
Please remember to recycle your old batteries and don't throw them in the trash to end up in a landfill somewhere where they can leak toxic chemicals into the ground and water supply. ♻️
wildwoodtraveler is offline   Reply With Quote
Old 07-24-2016, 08:31 PM   #10
They all leak eventually, from experience.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
battery
