Old 02-20-2016, 11:18 PM   #11
Too Tall's Avatar
Originally Posted by rockfordroo View Post
The 120v heater is for operating the fridge. The 12V heater is for the condensation strip heater around the door seal. The 2652 schematic shows a switch for the condensation heater. I think it may be item #66 on page 7 of the attached parts document. Looks like it's kind of hidden under the control panel. I have 2652 also, but haven't seen the switch. I'll have to look when spring arrives.
Glad you corrected me on that. So the only heater for the condensation is the 12 volt heater on terminal J2.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-21-2016, 10:09 AM   #12
Correct.
2011 Traverse LT, 3.6L, FWD
Old 02-21-2016, 11:07 AM   #13
PhoneDude 8289's Avatar
I sniped and caped the wire behind the light to the heater last year, no issues so far. If need be I'll put a switch on it. Light still works.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 02-21-2016, 02:43 PM   #14
So you're saying that the wire to the heater and the wire to the light join in light enclosure somewhere, i.e., it's accessible "at the light?"
What model, and do you have a pic?
Old 02-21-2016, 03:56 PM   #15
KyDan's Avatar
I pulled the cover off my light and snipped the wire going to the anti-condensation heater.
Light works but no battery sucking heater.
Yes it sweats a little in hot humid weather but it's never been a problem
for us.
Plus our fridge cools only marginally in hot weather and having a hot strip
of metal next to the cold area is not in the best interest of cold beer.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-21-2016, 04:16 PM   #16
Jerry01's Avatar
In another forum there is a discussion about this along with pictures. Here is the link. I'm not sure if there is an issue so it might get removed. Jerry
http://www.irv2.com/forums/showthread.php?t=113116
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 02-21-2016, 06:03 PM   #17
Dometic 2652, didn't take pictures when I did the mod. One thing I found strange was that the wires feeding the light and case warmer are of different gauges, the heavier gauge wire went to the light. I would have thought that the larger wire would have went to the heater.
Joe & Beverly
2014 8289WS lifted
Old 02-21-2016, 07:36 PM   #18
That's strange that the light would have a heavier wire, but I'm not surprised by anything these RV guys do.
I found the pic of the switch I was looking for. I don't know that every fridge with a switch has it here, but this is where it is on this guys fridge.
Name:	Dometic climate switch.JPG
Old 02-22-2016, 06:55 AM   #19
KyDan's Avatar
Hey-that looks like MY hand!!
Just to recap and maybe avoid confusion.
If you have the switch to shut off the heater - it will be found in the
area of the pointing finger! That is a foto of my previous unit. Note- in my
case I found that after traveling on an extra bumpy stretch of highway the
switch would be moved to a sort of center position where it was ON! I guessed
the freezer door trim was bouncing just enough to contact the
rocker and move it.
We boondocked one time and found our batteries sucked nearly dead in 2
days because I'd forgotten to check the switch. I popped the switch out
and taped off one of the wires to prevent that from happening again.
The OTHER switch we've been discussing is the interior light switch.
If you DO have the heater and don't have the little rocker switch (as
shown by the pointing finger) you can pull the cover off your light switch
and snip the wire going to the heater to permanently disable the 12v heater.
I've done that on my current unit and as mentioned I believe it was the
skinny wire going to the heater and the fatter wire powered the light.
Go figure- I'm not sure if the wire gauge was actually larger or the insulation was just thicker....
Finally if you decide to do this little mod be sure and disconnect shore
and battery power or you'll likely wind up looking to replace one of the fuses on back side
of the fridge! Ask me how I know....
Plus my fridge had an incandescent bulb and it would get hot enough to burn you
in mere seconds so you don't want it on with the light cover off.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-22-2016, 07:34 AM   #20
Herk7769's Avatar
For those without a switch:
Concept and photos from ZackDog at IRV2 -
1. Take the outside cover off and located the Junction box to find the J2 circuit and noted the diameter of the red wire.
2. Remove the light cover in the refrigerator and find the two red wires attached to the light switch. Pulled them out as far as possible and cut the one that is larger in diameter than the one identified in step 1.
3. Attach a female connector to the wire close to the switch and a male connector to the wire that goes through the hole in the refrigerator. Cover the male connector with electrical tape. If you need to use the heater in the future, just join the two connectors.
By doing it this way, the light still works.
ID:	100141   Click image for larger version
ID:	100142   Click image for larger version
HAM CALLSIGN - KC3FFW
battery
