Old 12-28-2014, 11:51 AM   #1
Battery Problem Wildcat 344 QB 2014
I am having a problem when I disconnect from Shore Power I have no battery power for interior lights, refrigerator, panel indicator, water pump. I know the battery is OK as the front and back jacks are working. Any suggestions.
Thanks!
pvarady1 is offline   Reply With Quote
Old 12-28-2014, 11:58 AM   #2
jtstromsburg's Avatar
I would guess there is a battery shut off in the off position. Mine got bumped once and it took me a bit to find it
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 12-28-2014, 12:06 PM   #3
That was what I was thinking but I have not been able to find one.
Thanks.
Old 12-28-2014, 12:12 PM   #4
Salt Shaker's Avatar
Mine was the opposite. One of my ground wires was loosely wrapped around a self tapping sheet metal screw from the factory.
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 12-28-2014, 03:46 PM   #5
Battery 2014 Wildcat
Had similar problem on 2011 Wildcat Sterling. Technician reached down to the right of the battery and 'reset a breaker' and power was restored. Follow up testing indicated a loose plate in the battery. Speculate this may have caused breaker to trip. Jaycee
jaycee is offline   Reply With Quote
Old 12-28-2014, 06:34 PM   #6
Thanks. I will check it out.
Old 12-28-2014, 07:08 PM   #7
Phat Phrog Stunt Crew
elind's Avatar
Follow the positive wire off the battery to bank of mini breakers. One of the mini breaker is tripped and there is a little button on the side of it. Just push the little button in and it's reset. Simple as that.
2014 Wildcat 327ck
elind is offline   Reply With Quote
2014, battery, cat, wildcat
