Old 12-13-2018, 06:29 AM   #1
Bedroom TV cable connection
In my Prime Time Tracer Air, I do not seem to be able to connect the TV to cable. The main TV works fine. I have tried various internal adjustments and it is not the TV or setting. Is it possible the bedroom TV connection is only hooked up to the aerial?
Ramblin Paul
2017 255 Prime Time Tracer Air
2011 F150, 5.0 L.
Equalizer hitch
90 days camping in 2017, 2018
Ramblin Paul is offline   Reply With Quote
Old 12-13-2018, 07:30 AM   #2
Coach
Are you sure you're plugged into cable and not satellite? Satellite ports generally don't get split and could be mislabeled as well. Also be sure your antenna booster is off and TV is set for cable. Beyond that you may need to start inspecting the cable port and splitters for good connection.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-13-2018, 03:50 PM   #3
bikendan's Avatar
I have the same issue, with my PrimeTime Air 255.
The cabling looks to only provide cable to the main tv. I'm looking to get a splitter or switch so the bedroom tv can also receive cable signals, not just antenna signals.
Equalizer WDH
Old 12-14-2018, 01:11 PM   #4
Bedroom cable hookup
Thanks Dan-was hoping I might hear from you as have the same unit. That was my thinking as well. Have not looked closely to see how easy to access the wiring. Other than that we really like the unit and have no issues with it.
Ramblin Paul
2011 F150, 5.0 L.
Equalizer hitch
Old 12-14-2018, 01:45 PM   #5
bob213's Avatar
https://imgur.com/R2BeLJ3
The middle wire is your cable input. With amp off it should send signal to tv2 wire on right
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is offline   Reply With Quote
Old 12-14-2018, 02:29 PM   #6
bikendan's Avatar
The problem is that the bedroom tv only has a single coax outlet plate, which leads just to the OTA antenna.
Equalizer WDH
Old 12-14-2018, 04:09 PM   #7
bubbles's Avatar
If you have a plate like the one referenced it is not only where the 12 volt antenna booster power is selected but it is also a splitter. The plate front will have the front TV coax output and the 2nd TV will be outputted where shown. The plate is a splitter and that is why the antenna booster switch needs to be off to get cable to all TV's.
Old 12-14-2018, 05:52 PM   #8
Are you sure the OUTSIDE cable connection is connected to the correct input? I think (not sure) the satellite input goes directly to the the main TV only, not to the booster and not to the second tv. The other outside input should go to the booster and splitter pictured above, feeding both TVs. Just for grins switch to the other outside input, turn the booster off, and check the bedroom TV. If that works then leave it connected as-is and change the main TV to the other output.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
bed, cable, roo
