Old 11-23-2010, 10:29 PM   #1
marialee-Berkshire410qs
marialee's Avatar
Berkshire Furnace
We have a Berkshire 410qs. The gas furnace won't keep the temp I have programed in. It is cold so we keep the propane furnace on at 50. I have to check on it every few hours to be sure it keeps the correct temp. I have a seperate thermometer that states 38. So I turn the furnace off, then turn it back on. What could the problem be? Don't want my pipes to freeze.
marialee is offline   Reply With Quote
Old 11-23-2010, 10:40 PM   #2
Villa Estate 392FLFB
The_Stuff's Avatar
check your propane tanks/lines. might be freezing up. ive had that happen to and its mostly from the furnace running too much without a break. if you can plugin use electric heat.
One state/province at a time!
The_Stuff is offline   Reply With Quote
berkshire
