Old 01-09-2016, 12:01 PM   #11
Amazon has a complete SWM dish pack comes with all needed items and a carring case for $163us.
j free is offline   Reply With Quote
Old 01-09-2016, 12:06 PM   #12
I know you don't want the $1500.00 antenna; however, you may want to reconsider. I am on my second RV with the same antenna and it performs flawlessly. The first thing I do, after I get level and shore power on, is turn on the antenna. While it automatically adjusts I finish setting up and am watching TV in no time. The only drawback is ensuring that you always have a clean line of site to the sats. Also, you will not get local stations outside of your home viewing area so you will need to receive the major networks OTA.
Middleburg Redneck is offline   Reply With Quote
Old 01-09-2016, 12:25 PM   #13
With a little practice, a compass and a sat meter, you will be able to set up a portable dish in about 10-15 minutes. I have mine mounted on an old Xmas tree support with 4 legs. I like the fact that it doesn't weigh much, is low to the ground, can be put anywhere withing 100 feet of the TT, and less likely to tip over than a tripod.
It is even simpler if you only want SD channels, because they are available on one satellite, and can be received on a smaller dish.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 01-09-2016, 02:50 PM   #14
Rvdixie's Avatar
For Approximately $550.00 you can buy a carry out from Winegard which finds the satellites all by itself and if you hook up the dish when you first pull in by the time you set up you are ready to watch tv. They make one for Direct TV and it should be about a $6.00 add on to your current Direct Bill. Well worth the extra money for the lack of aggravation. Sometimes it's easier to spend a little more up front and eliminate the problems.
Richard & Rosalba Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
Rvdixie is offline   Reply With Quote
Old 01-09-2016, 03:26 PM   #15
Does not work on DirectHD and definitely does not work with the Genie
donniedu is online now   Reply With Quote
Old 01-09-2016, 04:54 PM   #16
Rvdixie's Avatar
I don't know where you got your information but I have been using it with Direct TV for 4 months now both in TX and in FL. I don't know anything about a Genie whatever that it. All I know is I get the same Direct TV stations I get at home with the exception of the local programs.
Zephyrhills, FL
Old 01-09-2016, 08:14 PM   #17
Swift2
Swift 2's Avatar
We have the ab connector instead of the SWM system and we still get HD just fine. The satellites have changed from 110 to 101 for the center satellite for the HD. We have the larger dish and a standard LMB (3 head receiver). The direct tv tech just came out on my request to verify everything was set up right and working. Old system was passed with flying colors.
Swift 2 is offline   Reply With Quote
Old 01-10-2016, 06:13 AM   #18
nomad297's Avatar
You cannot get DirecTv HD programming with your setup. Sure, you can get SD off of satellite 101, but your dome and all other domes are not capable of picking up satellites 99 and 103 which carry the HD programming.
Bruce
nomad297 is online now   Reply With Quote
Old 01-10-2016, 07:48 AM   #19
Originally Posted by nomad297 View Post
.....buy their heavy duty tripod kit and you will soon be an expert at setting up your satellite. The folks at tv4rv will help you with any aspect of satellite for your RV.
With my setup from tv4rv, I take no longer than ten minutes to get tuned in to the three satellites needed for HD DirecTv.
Bruce
This (with a cavet, read below)! If your looking for an "all in one" solution, TV4RV's Heavy Duty Combo Package is probably the most complete and sturdiest setup you will find. I use it with an extra SWM 5LNB Slimline dish I already owned. That setup has now twice, survived severe thunderstorms with 50+ mile wind gusts.
In hindsight, I found I could have gotten what I needed for a little less by buying a Bosch BT160 tripod that can be had on Amazon for 35.00-40.00. Home Depot also sells them, but at twice that price. It is the same tripod that TV4RV sells, but just a different brand. What TV4RV sells is a CST/Berger. Then you could just order the custom replacement mast and flat head bell housing from TV4RV for another 60.00 and by removing one bolt on the head of the tripod, replace the Bosch pieces with the TV4RV ones. Pick up a screw type dog stake and ratchet strap from almost anywhere for a few more bucks and you have the same tripod setup TV4RV sells for approx. 100.00. What you get from them for the extra 60.00 is their Bungee Cord, Bubble Level, Lensatic Compass, SF-95 Satellite Finder, Leg Restraint Kit and Heavy-Duty Handy Carry Bag. Your choice if you need the "extras". Personally, I have never used the bungee cord, compass or leg restraint kit, however I could see the use of the leg restraint kit if your setting up the tripod in a parking lot or other "hardened" surface. The zipper on the carrying bag broke the second time I used it, and their sat finder won't allow a SWM signal to pass so you have to keep taking it in and out of the line to get signal strengths to show on the receiver so although it is useful, it can be a pain if you need to do it more than once. I bought some quick connect coax connectors which makes it a little easier to swap in and out.
I use a small bubble level I already had to level the tripod and found an android app called Satellite Dish Finder that not only replaces a compass, but allows me to quickly locate where to place my dish, especially if I am trying to get thru some fairly heavy tree cover at some campgrounds. Setting up the dish, 5 minutes. Aiming to get a working signal - another 5 minutes and tweaking the alignment to maximize the signal and done.
As for receivers, I am using an HR44 in the living area of our trailer and a H25 mounted to the back of the bedroom tv using the wall mounting bracket. I can then easily move the 32" TV/receiver from the bedroom to the outside patio area as one unit.
Good luck!
Jay
2016 Coachmen Freedom Express Liberty Edition 322RLDS (Sold)
2017 (SOB) Jayco Eagle 330RSTS
2015 GMC Sierra 2500HD SLE Gasser
blujay40 is offline   Reply With Quote
Old 01-10-2016, 11:44 AM   #20
Masterchip
masterchip's Avatar
DirecTV HD setup
I purchased my HD setup for DIRECTV off of amazon. Complete kit with everything one would need for less than $150 with tax. Got a professional meter from amazon (used) for $100. Now takes 10-15 minutes to get the signal to the RV, another 10 minutes to set up.
2012 Ram 2500
2013 Columbus by Palomino 29'
masterchip is offline   Reply With Quote
