Old 10-06-2016, 12:52 PM   #11
talldiver's Avatar
I bought the Splendie combo washer/dryer, vent kit, 90 elbow and secure fit mounting brackets all from Amazon. It installed easily after almost drilling through a stud. My unit had a label on the wall indicating "drill here for dryer vent" Don't believe them!! Drill the pilot hole as suggested above and find the stud placements. Drilling the hole is easy after that. Now I have a 3/4 moon hole on my wall.
I would also recommend buying fail safe water hoses to replace the ones provided with the washer/dryer. The ones with the unit are, in my opinion, no good.
Good luck with the install.
2015 F350 SRW 6.7 PSD
2016 38FB2 CC
Days Camping (2017) - 23 to date
Days Camping (2016) - 62
Days Camping (2015) - 23
Days Camping (2014) - 15
talldiver is offline   Reply With Quote
Old 10-06-2016, 02:05 PM   #12
Is there a problem drilling through a stud? On my Cedar Creek I had no choice
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 10-07-2016, 12:26 PM   #13
SlowrideHD's Avatar
got it installed
I ended up going to my local RV store and purchasing the vent kit that they use themselves. It's similar to the one pictured above but had a glossy black cover. I used a 4" Milwaukee hole saw for cutting through the wall once I drilled a small pilot hole all the way through. I went just a touch left and below where the factory "drill here" sticker was because of a piece of wood trim at the back of the closet. Then I used the hole saw to cut through the interior wall first then moved all the insulation aside to make sure wires or some other obstruction was not in the way. Then I went outside and following my original pilot hole, drilled out the outside 4" hole. The sleeve of the vent kit lined up very well. I did put a thin bead of silicone caulk on the flange of the sleeve and also a very thin bead on the edges of the vent sleeve cover before screwing them into place. The 2 foot long piece of foil vent line was not long enough so I went to the local big box hardware store and bought an expandable to 8 feet long flexible vent line (not the foil type). Everything went well with the install of the Splendide 2100XC although I did not use the supplied washer hoses that came with it. Instead, I bought some stainless braided water hose washer lines that are guaranteed never to split or leak. I didn't take long to install but I did take my bedroom door down to get it through. While my bedroom door is down, I covered some industrial size q-tips with wood glue and inserted them into the door hinge holes, then snipped them off flush. That way my screws will go back in good and tight when I put the door back up.
Washing a load of clothes now just to see how it all works out!
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 10-07-2016, 01:14 PM   #14
Installing mine was something I would not wish on my worst enemy. Camping World said they would install the washer/dryer for $400 bucks, I wish I had let them. Now the dryer has to come out because something is wrong with the motor. I am taking the camper to IN for cap replacement and at the washer/dryer place they are going to fix it. I tried to tell them how hard it was going to be but the man told me not to worry they could get it and fix it and then put it back.
Old 10-07-2016, 01:38 PM   #15
I have a 15 32RL Cedar Creek and it had been prepped for a washer/dryer but I don't think that Cedar Creek ever intended for anyone to ever install a stacked unit in that closet. The only possible way to install the vent for a stacked unit was to drill through a stud. You could put in a combo unit but the stacked unit was a problem. I have 2in on each side to play with and 2in on top and 3in in the front. I had to saw off half of the vent tube, then after the unit was in place reach through the hole and then pull the exhaust hose through the hole and hook it up to the vent tube. I sent Cedar Creek a email asking how I could put the vent in and I never heard anything back. I called Denise and left a msg and nothing. The 32RL is not made anymore, we love the camper and have no plans to ever trade. The washer/dryer sits on top of the furnace and the bathtub is right behind the closet.
Old 10-07-2016, 07:19 PM   #16
The chrome one looks nice.
DRYER VENT KITS
The only Dryer Vent Kits designed specifically for OEM and aftermarket RV installations, Splendide's Deluxe and Standard Dryer Vent Kits include everything you'll need for a quick, easy, and safe vented dryer installation.
Part No.
VID403AC
UV protected, weather-resistant vent cover with automotive chrome finish and streamlined design. Kit includes Integrated 4" plastic tail piece and flap/insect seal, 2 worm-driven metal clamps, 4" x 2' fire-resistant flexible metal duct, inside collar, 6 screws.
Fits
WD2100XC/XCP
TVM63X
Part No.
VID403A
UV protected, weather-resistant vent cover with paintable white finish, integrated 4" plastic tail piece and flap/insect seal. Kit includes 2 worm-driven metal clamps, 4" x 2' fire-resistant flexible metal duct, inside collar, 9 screws.
Fits
WD2100XC/XCP
TVM63X
Part No.
DB402
(W, WO)
Lightweight, paintable vent assembly with integrated tailpipe and flap/insect seal. Telescoping design adjusts from a wall thicknesses of 1 " to 2 " for improved seal, cleaner outside appearance, and easier painting. May be bonded directly to outside wall. With (W) or without (WO) outside screw holes.
Fits
WD2100XC/XCP
TVM63X
Part No.
VI422
UV protected, paintable louvered vent with 4" metal tail piece and recessed mounting screw holes for a clean appearance, 2 worm-driven screw clamps, 4" x 2' fire-resistant flexible all-metal duct, inside collar for finished interior look.
Fits
WD2100XC/XCP
TVM63X
Part No.
VI490D
Lightweight, aluminum close-wall dryer offset elbow, turns 90 within 4-1/2".
Dimensions: 10-1/2"H x 4-3/4"W x 4"D
Fits
WD2100XC/XCP
TVM63X
Newtm is offline   Reply With Quote
Old 10-07-2016, 08:23 PM   #17
Iggy's Avatar
Here is what mine looks like.
It is just a short flex from the washer/dryer to the vent.
All I needed was the 2ft of hose the most.
ID:	122384   Click image for larger version
2012 Georgetown XL - 378TS
Old 10-08-2016, 12:04 PM   #18
SlowrideHD's Avatar
My Install
Some pics from my installation.
ID:	122427   Click image for larger version
ID:	122428   Click image for larger version
ID:	122429   Click image for larger version
Name:	To Outside.jpg
Old 10-08-2016, 12:32 PM   #19
I think I would get regular vent pipe and route it up the wall over to the corner and then 90 out the wall. Anchor all the pipe to the wall. Arrange it all low behind the unit close to the floor.
Old 10-08-2016, 07:18 PM   #20
SlowrideHD's Avatar
efficient vent
The shorter and most direct route from dryer to wall vent is the most efficient. Right now my vent opening is approximately the same height as the dryer connection. Going down toward the floor would add a lot of length and unnecessary bends.
Also, this type of vent line flows a lot better than the foil type which came with the Splendide vent kit. The way it is routed now makes it not visible unless you look over the top of the combo unit.
vent
