Old 06-19-2013, 08:51 AM   #1
jlbreaux's Avatar
Blower/fan shutting off while compressor running
I have a 2011 356QLB, I believe it has a 15,000 BTU A/C system. The issue I am having is that the blower/fan will kick off for a few seconds and then kick back on, while the blower/fan kicks off I can still hear the compressor running. It does not do this all the time, but it has done it enough to catch my attention. Any idea what may be causing this problem, or if it is even a problem?
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 06-19-2013, 11:33 AM   #2
I noticed mine doing this a few days ago. I have my thermostat fan set to auto, and it was trying to switch it to low fan speed from high. It took it three attempts before the fan switched to low. It was in the evening, and I'm guessing the system figured out a lower fan speed would get the job done. It's just my impression. I'm not sure how smart the thermostat is.
Frankm2 is offline   Reply With Quote
Old 06-19-2013, 11:44 AM   #3
yvesm's Avatar
Yep, its the fan going from high to low or low to high. If there is too much of a difference ( 5 degrees maybe, check t-stat manual) the fan will adjust its speed to cool down the coach faster.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 06-19-2013, 12:16 PM   #4
jlbreaux's Avatar
OK, that makes sense, but I thought the fan only had one speed. I guess I will have to find the manual and do some reading.
Old 06-20-2013, 06:07 AM   #5
Herk7769's Avatar
Not sure about that. My money is on "Your fan motor is overheating." There is a thermal switch inside the motor that can open when the windings get too hot.
Take the cover off and check for debris on the condenser cooling fan and lubrication on the fan shaft.
HAM CALLSIGN - KC3FFW
Old 06-21-2013, 11:18 AM   #6
jlbreaux's Avatar
Thanks,I will check that for sure. It seems to me if the fan motor is getting hot wouldn't it kick off for more than one or two seconds? Just thinking out loud.
Old 06-21-2013, 01:30 PM   #7
Herk7769's Avatar
Yea, me too (without being there).
