Old 07-05-2019, 01:01 PM   #1
Blown microwave
Has anyone had a microwave do this. 2007 V-Lite . It still works or seems to.
Don't know how or when it happened. Thought it was fine when we put it up for winter. Got it out to get ready for a trip and found this. The glass on the turntable was also broke
JHayes55 is offline   Reply With Quote
Old 07-05-2019, 01:26 PM   #2
Coach
is there a picture forthcoming?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-05-2019, 02:14 PM   #3
There was supposed to be two photos. Guess I did something wrong
ID:	209019   Click image for larger version
Old 07-05-2019, 02:39 PM   #4
Flybob's Avatar
The hole below the burn mark is where the microwaves enter the cooling chamber. It is normally covered by a mica window that is transparent to microwaves. If it gets covered with food it can burn as the food heats up. The oven will work but you should not use it too much before you replace it. You can buy them and easily replace it. Search mica and your oven maker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-05-2019, 02:56 PM   #5
Selective Curmudgeon
Halfmast's Avatar
Something similar happened to me with my Flagstaff pull trailer. A loud bang then RIP microwave.
I priced Magic Chefs then quickly ruled that out. I took the dimensions of the microwave height, width, depth and found something on special at Target for $50. Red! Really added some color.
As long as the microwave is no larger than the opening of the decorative flange(?), escutcheon plate(?) cover(?), a no-name replacement will work, though you may have to slightly adjust that decorative cover when screwing it back on. Don't worry about the new microwave being an inch or so smaller all round. Once installed, it's pitch black back there, you don't notice it.
There is an anchor bracket that screws into the back of the microwave. I think I had to drill a pilot hole into the back of the new microwave to get things lined up. Check to make sure that you have a screwdriver that fits those screws.
If necessary, swap out the feet to get the replacement at about the same level.
It was relatively straightforward, and I can barely figure out how to get the lid off the peanut butter jar.
2016 Ford F350 Diesel Dually
2018 Coachmen Chaparral 360IBL
Halfmast is offline   Reply With Quote
Old 07-08-2019, 09:03 AM   #6
We ordered a new Microwave that fits.
The Cover over the area was laying on the glass turntable and was partially melted.
I have yet to figure out the reason for this to happen but will not be taking any chances with the old one.
Thanks to everyone for their responses.
Old 07-08-2019, 09:21 AM   #7
Citrus County, Fl.
GL1800Rider's Avatar
You might want to advise the manufacturer. This is why fire reports ask for make model and serial number so it can be tracked. Could lead to a recall.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 07-08-2019, 09:35 AM   #8
Broken Toe
Cowracer's Avatar
Originally Posted by JHayes55 View Post
I have yet to figure out the reason for this to happen...
Looks to me like some part of the insulation for the magnetron gave out causing arcing. You know how you can get an arc if you accidentally microwave a spoon in your coffee cup? It'll do the same thing to the metal of the cabinet if the insulation fails. That arcing also probably blew out the mica window.
That you got 12 years out of a consumer-grade microwave is impressive. Usually 3-5 years is about as far as they will make it .
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 07-08-2019, 09:40 AM   #9
Flybob's Avatar
The mica cover can get covered with grease and food particles which do generate heat from the waves and will burn.
TST Tire Monitors
2 100W solar panels
microwave
