Old 01-15-2014, 02:05 AM   #1
TxTravelingRN's Avatar
Blu Ray
Has anyone seen an RV furnished with Blu Ray systems rather than the standard DVD? Anyone modified their system and used Blu Ray as an add-on? Have a few dozen Blu Ray discs at home and would sure like to view them instead of having to purchase separate DVD's.
TIA
2013 F350 Lariat 6.7 Diesel DRW
2013 Rockwood Ultralite 2608 WS
2013 Days Camping: 61
2014 Days Camping: 200+
TxTravelingRN is offline   Reply With Quote
Old 01-15-2014, 04:00 AM   #2
kc8lvy's Avatar
Under my tv there is a spot for my Blu Ray and my Dish Receiver both are hooked up and work great.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 01-15-2014, 08:04 AM   #3
I did the same thing. Installed a Sony blue ray/DVD/AM/FM home theater system under the main tv in the living room. Had to wire it for surround speakers. Just time for running wires and mounting speakers. I also installed a new tv. Both systems are wireless, Internet and Bluetooth ready.
Love it
I can post pics if you like.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 01-15-2014, 02:37 PM   #4
Post some pics if you could. Sounds like a nice setup. Want to do minimal alterations until warranty expires.
Old 01-16-2014, 12:02 PM   #5
Here are some pics
I replace the TV that came the unit. It was a Toshiba 40"(Bad TV. Forest River reimbursed me for a TV that I bought locally). So I was able to purchase one that I really wanted, with all of the bells and whistles. The TV I put in was a 42" Vizio. The Vizio was actually narrower and not as tall as the Toshiba because the bezel was only 1/2" wide all the way around. To my advantage. I first took out the small board above the original TV that gave me about 2" more height. I purchased shelving material from Lowes that was the same color as the cabinet. I believe it was called cherry color. Almost an exact color match. 12" x 48" piece gave me enough material to make a shelf and two uprights to support the shelf on both side. I also installed an upright in the middle. I used the same bracket that the old TV was attached to but had to flip it and drill 4 mounting screws to the TV.
As for the stereo I ran the speaker wire through the floor behind the entertainment center and attached it to the PVC conduit under the slide out so it would move with the slide and not get pinched anywhere. On the main slide out I drilled a couple of small holes in the 2" square tubing the the slide out is on. As you can see in the pics. This was the easy way and shortest. I did purchase wire and spliced it in to give me enough wire to run the speakers up the wall and mounted them at ear level. I placed the subwoofer behind the recliner. It was a perfect fit. If you do not want to drill small holes in the 2" tube then you could run the wires back to where the power wires are for the main slide out and attach them there. Just more work. Remember to keep the polarities correct for the speakers.
I have not done so but will be installing the coaxial antenna inputs for the direct TV receiver under the right hand slide out. Should not be an issue. One could install the receiver in the cabinet where Forest River intended it to go but it only has coaxial cable going to the TVs but I wanted HD in the motorhome.
Name:	ImageUploadedByForest River Forums1389891190.320813.jpg
ID:	45006Click image for larger version
Name:	ImageUploadedByForest River Forums1389891211.365344.jpg
ID:	45007Click image for larger version
Name:	ImageUploadedByForest River Forums1389891222.438732.jpg
ID:	45008Click image for larger version
Name:	ImageUploadedByForest River Forums1389891243.754802.jpg
ID:	45009Click image for larger version
Name:	ImageUploadedByForest River Forums1389891255.473779.jpg
ID:	45010Click image for larger version
Name:	ImageUploadedByForest River Forums1389891265.349901.jpg
ID:	45011Click image for larger version
Name:	ImageUploadedByForest River Forums1389891278.865585.jpg
ID:	45012Click image for larger version
Name:	ImageUploadedByForest River Forums1389891290.381682.jpg
ID:	45013Click image for larger version
Name:	ImageUploadedByForest River Forums1389891299.164647.jpg
Awesome sound and picture
My wife likes the Bluetooth capability to play her music and answer the phone through the radio or tv. The wireless on both of them allows me to download content like Netflix from the Internet and stay connected with all of our devices.
Now this is camping!
Vizio TV model 42" M series. 3D wireless and Ethernet ready
Sony Home Theater model BDP-S3100 Blue Ray 3D wireless and Blue Tooth ready
Direct TV HR24-500
2008 Honda CR-V
