Old 02-03-2014, 08:24 PM   #11
TURBS's Avatar
Originally Posted by cedar creekin View Post
Well after the campground never coming to check my voltage at the 50 amp box I bought myself a new multimeter and started checking myself.
Everything looks ok, 235v at the box, and 116v at the outlets inside the camper while one a/c is running. A touch low, but within spec.
My inverter/converter also checked out good.
Surprisingly after everything checked out my front a/c started acting normal again. (I'm thinking that I had a low voltage situation)
Either way I like your suggestion Turbs and I will def look into that meter.
I really am glad I installed the progressive industries surge guard with remote pendant.
I bought mine from a fellow frf user whom upgraded his camper and it was 50 amp so he no longer needed the 30 amp one that was a year old.
they come up once and a while on the classifieds but go quick.
its a very small investment considering what can be damaged from a voltage spike or low voltage.
OR even worse a power poll thats wired wrong.......
Old 02-03-2014, 08:41 PM   #12
Infractee
235V?!?!? We no likey the 240V!
You must have measured across the two hot leads to get the 235V, measure from each hot to the neutral to get your correct voltage being used by the camper, measure both sides to make sure they are near identical, if not there is something wrong with power pole and this will cause a "brown out" type situation.
RhoZeta is offline   Reply With Quote
Old 02-03-2014, 08:51 PM   #13
cedar creekin's Avatar
I failed to mention that I did check each leg, & IIRC it was 116-117-ish, I forgot to post that.
I also checked both hot and seen the 235v.
2003 cedar Creek 36 RLTS
Pushing an F350 diesel
Trailair
US Navy Persian Gulf Vet 1991-1994
cedar creekin is offline   Reply With Quote
Old 02-03-2014, 08:56 PM   #14
sherdep's Avatar
sounds like you had an under power condition - luckily no significant damage
I have a device I plug into the power before I plug my camper in to make sure the power is good and wired correctly.
camping world sells them - here is a link Digital Line Monitor - TRC AECM20020-012 - Surge Protectors - Camping World
you will just need the plug conversions from 110 to 30 amp to work for your application or just run it inside in one of the outlets.
eventually I want to get a 30 amp hard wired surge protection with the remote display like this one - 30A Hardwire Surge Guard - TRC 34520-002 - Surge Protectors - Camping World
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-04-2014, 02:42 AM   #15
AquaMan's Avatar
Both a/c's acting funny today
I have found that makariosrv.com has the best prices on the Progressive Industries EMS.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-04-2014, 06:26 AM   #16
TURBS's Avatar
I would go with the ProgressIve industries unit.
Lifetime warranty and made in the usa.
TURBS
oc's buddy
