Specs say 13.2 Amps at 115V.
http://www2.dometic.com/dc0efb6a-748...1e5780a8.fodoc
Was your AC loud ? mine is so loud you can hardly hear the TV. The TV is mounted almost under the AC unit. If you pull the registers off and reduce the restriction mine is not as loud. I have been looking for a solution and it appears the vent manufacture makes a better vent that is adjustable and you can close off the vent so you can have more airflow where you need it. FR needs to find a solution.
Can you have the AC guy check the current draw after it is fixed and post it please?
A hot RV is no fun during the summer, especially if your wife is pregnant. Hope they get you fixed up.
