Old 06-30-2014, 10:39 AM   #1
Cab Over Entertainment
I have a 2014 Forrester with a VSIO TV in a cab over entertainment configuration. I was wondering how do you get to the back of the TV?
Any help to this puzzle will be appreciated.
coldj is offline   Reply With Quote
Old 07-09-2014, 10:39 PM   #2
Try lifting it straight up gently, mine rests on some pegs that stick out of the mounting frame. Be careful of the audio and cable attachments, mine didn't have much slack. Good luck!
darthdavo is offline   Reply With Quote
Old 07-09-2014, 10:44 PM   #3
although not same setup, mine had feet on the bottom of the wall that screwed out to keep pressure on the back of the TV and keep it from bouncing. I had to turn them clockwise to loosen the tension on the bottom of the TV then lift up the TV to remove it from the mount.
Sans1
2014 3010DS (Ford Chassis) no more
Back to a fiver - after 6000 miles in it, me no likey motorhome
Sans1 is offline   Reply With Quote
