Old 03-07-2015, 11:36 PM   #1
Cable hook up at campground
Help!!! I just bought a 2015 surveyor cadet 294. None of my connections seem to work. I have to connections outside simply marked cable/satellite. Inside I have connections labelled satellite and tv 1, and then a sat 1 and sat2. I've tried both connections outside and all inside and nothing. I'm losing my mind!
2015 Surveyor Cadet 294 QBLE
jewhitehead is offline   Reply With Quote
Old 03-07-2015, 11:40 PM   #2
geotex1's Avatar
The factory has been known to mis-wire the inside plate. Try cable outside and then connect to satellite inside. If it works, pop off the inside plate and switch the coax.
geotex1 is offline   Reply With Quote
Old 03-08-2015, 12:10 AM   #3
I connected to cable outside and tried all inside connections. Then outside sat and all inside connections and still nothing. Changed tv input from air to cable and still no dice. I guess tomorrow when it's not freezing I'll take apart some stuff and chase wires.
Old 03-08-2015, 12:47 AM   #4
TURBS's Avatar
After changing inputs did you re search stations?
Old 03-08-2015, 01:03 AM   #5
Always Learning
And, just to make sure- was your antennae booster off?
And finally- have you tested the campground's cable connection directly with just a wire and a TV?
Old 03-08-2015, 08:18 AM   #6
DaveSchwartz's Avatar
The booster is not just a signal amplifier, its a switch that selects between the rooftop antenna and the sidewall cable connection in order to route either signal via a single cable to the TV. The green light must be off to use the sidewall cable input. And, yes, a channel rescan on the TV will probably be necessary too.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 03-08-2015, 08:52 AM   #7
At first the switch was on, then after researching I turned it off but it made no difference. I've not tried connecting directly to the tv. I will later today.
Old 03-08-2015, 01:20 PM   #8
Maron
Send a message via Yahoo to Maron
Also check the TV set up for input such as HD1 etc.
Maron is offline   Reply With Quote
Old 03-08-2015, 05:31 PM   #9
on my booster it has two coax connections ,try the other one? every thing else has been covered good luck ,there is a solution!!!
Big Bill is offline   Reply With Quote
Old 03-08-2015, 06:40 PM   #10
last thought , is there signal at the cg post?
Old 03-08-2015, 07:28 PM   #11
Button's Avatar
Direct tv told us that satellite dishes won't work through splitters in campers. cable needs to run direct to tv. we had to do this on the 5th wheel we had.
Button is offline   Reply With Quote
Old 03-08-2015, 07:44 PM   #12
Bill, I did try both connections at the switch and nothing. I have not verified if the cg connection even works. We are just now coming in on the train from the Grand Canyon. I'll see what I can find out a little later. Don't want to miss the Walking Dead!
Old 03-09-2015, 08:55 PM   #13
Cable Hook Up At Campground
You need to connect the Campground cable to the Cable connection and then make sure your Antenna Amplifier is turned off inside. the run a TV channel scan on your TV to get the available channels.
speedozeke is offline   Reply With Quote
Old 03-11-2015, 12:45 AM   #14
Sorry for the late reply, been on the road. Finally got it to work. Issue was I have a universal directv remote. I could access the menu but not make selections. Once I figured out how to do that with the tv buttons I ran the channel search and all was good. Trouble is the new campground in Las Vegas doesn't have cable hook ups!
mpg
