Old 03-08-2015, 08:21 PM   #1
Cable Input??
Just purchase my Wolf Pup 16 and have not clue how to get cable going. I have one hook up outside by front door with the TV mount and also one inside by door front. Where is the "input" cable hook up?
jdwilson128 is offline   Reply With Quote
Old 03-09-2015, 04:18 PM   #2
It should be on the outside.
whj77372 is offline   Reply With Quote
Old 04-14-2015, 07:29 AM   #3
Were you able to find it? I have the same issues with my 16BHS.
jsjungle is offline   Reply With Quote
Old 04-14-2015, 07:35 AM   #4
Nope. I don't think they have it. You have the roof mounted antenna and that is what the 2 cable jacks are supplied with.
Old 04-14-2015, 07:49 AM   #5
Great thanks, the roof antenna also does not work properly so I guess I'm stuck. Thanks again for your input.
Old 04-14-2015, 08:01 AM   #6
Make sure on the face plate of the jack inside by the sink you push that little button and the green LED light is on. That enables your antenna.
Old 04-14-2015, 08:07 AM   #7
Herk7769's Avatar
Some examples of what you are looking for.
ID:	74214   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 04-14-2015, 09:13 PM   #8
FYI...Winegard makes a small antenna attachment which only cost about $20 to $30 dollars. It just snaps onto the existing roof antenna. This really increases the reception on the antenna by a lot. Make the investment as you will appreciate what is does in regards to local channel pick up.
Also alway be sure to turn on the power booster which is the little button on the cable connection panel as shown in the picture above. This only need to be on for ANTENNA only not park cable or satellite. If you have cable connection behind your TV, you will have to change it to TV Antenna or Cable depending what you plan to use where you are camped.
DodgeChallenger2014 is offline   Reply With Quote
Old 04-14-2015, 09:17 PM   #9
Thanks all, your feedback is greatly appreciated.
Old 04-14-2015, 09:59 PM   #10
Evereddie's Avatar
I'd say even more than a lot. Like worlds of difference.
Evereddie is offline   Reply With Quote
