Old 10-11-2016, 05:06 PM   #1
cable reception
I am a newbie with a Blue Ridge 3125. i cannot get cable to come in clearly. I have the booster shut off but it is still snowy. Any thoughts?
waynef is offline   Reply With Quote
Old 10-12-2016, 07:20 AM   #2
Herk7769's Avatar
I am assuming you did a rescan of the TV using the cable setting (required because your TV uses a different internal tuner for cable called CAMS). During the scan you must select cable instead or "air" or "Antenna".
Can you see all the cable channels snowy?
If so, you may have a bad cable, splitter, or, cable connection in the walls (which is not unheard of).
HAM CALLSIGN - KC3FFW
Old 10-12-2016, 10:26 AM   #3
cable reception
Thanks, I have come to the conclusion that there is a bad connection somewhere. Two televisions have the same problem.
Thanks for responding.
Old 10-14-2016, 09:02 PM   #4
I'm relatively in the same boat. Connected from the cable campsite into the correct input externally plugged into to satellite output under the TV with the booster of and a cable rescan with no channels to be found
Coachman 2015 apex 259bhss
Firemedic is offline   Reply With Quote
Old 10-14-2016, 09:52 PM   #5
Dannimal's Avatar
I had the same problem with the cable not working on either TV. After much searching and testing, I found that the problem was with the jack that contains the antenna booster that routes the cable around the trailer. I replaced the jack containing the antenna booster and all is now working as it should.
2011 Sabre 29CKDS 5er
2005 Keystone Hornet 245RKS 5er (sold)
2000? Trailmaster M220 bumper pull (sold)
2016 Ram 2500 Cummins
Dannimal is offline   Reply With Quote
Old 10-14-2016, 09:57 PM   #6
Well my 1 year warranty ends at the end of the month. I guess I should include it on the list of 5 other issues found and never fixed
Old 10-14-2016, 10:02 PM   #7
Herk7769's Avatar
The satellite connector is not correct. All you need to do is turn off the booster power and rescan as if you were connected to the roof. The Booster switch also switches between the roof and "cable" automatically.
The SAT connection is "home run" to the exterior SAT input (if your camper has one); otherwise it is not connected at all.
Name:	Winegard wall plate rear.JPG
Old 10-14-2016, 11:03 PM   #8
Sweet so. Exterior to tv output with booster off then scan
Old 10-15-2016, 12:05 PM   #9
Herk7769's Avatar
Exterior "CABLE" connected to the Park cable connector; turn off booster (light off); rescan TV.
Do not use the AUX/SAT connection at all.
Name:	CBL and SAT inputs.jpg
Old 10-15-2016, 01:25 PM   #10
Left Coast
If condition persists, pull wall plates (inside and out) and tighten connection
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
