Old 08-03-2012, 04:47 PM   #21
Namchief's Avatar
Originally Posted by DualSport View Post
Multiple TVs isn't the issue.
I just want to connect my Satellite receiver box to the HDTV in the Entertainment Centre (don't plan to use the bedroom TV or outside TV hookups). My Sat Receiver needs 2 inputs from the dish but there is only 1 sat-grade coax at the UDC external hookup (UDC - universal docking center in Forest River language).
The Satellite service provider says a "splitter/combiner/switch/whatever" will not work. I'm hoping that's just Company Policy and that someone has already found a box that will feed both receiver inputs from a single coax from my dish.
Try looking at thisstacker destacker unit
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 08-03-2012, 07:24 PM   #22
DS ADV Rider
Looked at the link and the schematic diagram is EXACTLY what I want to do. It's for Sky TV in UK but I'll check this out further.
Thanks.
DualSport is offline   Reply With Quote
Old 08-03-2012, 07:48 PM   #23
Herk7769's Avatar
I tried to click on that to determine what it costs and it won't hook me up. Anyone have an idea? Looks expensive.
HAM CALLSIGN - KC3FFW
Old 08-03-2012, 10:43 PM   #24
DS ADV Rider
I couldn't get the Price link to work but Googling "Stacker Destacker price" brought up lots of hits. Seems like it's about $150 but if that's the only way to get the two Sat signals into my RV without ripping open walls, etc then the price is OK for me.
All the hits I got were for UK companies as Sky TV seems to have gone the same route as my provider, Shaw Direct, and used a HD PVR that MUST have two separate signals from the LNBs on the dish..
I still need to find out what grade of Coax is in the "Cable" wiring in the LaCrosse. If it's the same as the "Satellite" coax then I can probably use both at the same time (assuming they both come out in the entertainment unit). I don't get the trailer for a week or so and I'll physically check how it's wired then. I'll probably also contact Forest River Tech Support and see if they can provide specs and schematics for this unit.
Thanks to all for the help
Old 08-04-2012, 01:09 AM   #25
Namchief's Avatar
Check this out DSS Stuff
and read this http://www.dslreports.com/forum/r181...-feed-possible
1999 Yamaha Grizzly
Old 08-04-2012, 10:59 AM   #26
DS ADV Rider
I read the links and this is starting to sound a bit too technical for a DIY job. I think I should contact a local Sat installer to see if they have done any work on RVs and know how to handle this.
Thanks.
Old 08-04-2012, 05:33 PM   #27
Herk7769's Avatar
Print out and show them the sat/cable mod.
I think they will like the KISS of it.
Old 08-09-2012, 09:48 PM   #28
DS ADV Rider
I contacted Prime Time to find out the type of coax used for the "Satellite" and "Cable" connections. They confirmed today that all the coax in the Lacrosse 301RLS is the same type and is RG-6. They also said there were no wiring schematics available for the coax wiring.
There's lots of space behind the antenna booster/splitter switch, and it's beside the Sat outlet next to the TV, so I plan to do the mod suggested by Herk.
Thanks for everyone's help
Old 08-15-2012, 10:28 AM   #29
DS ADV Rider
Got our new trailer on Friday and we're away on a shakedown trip. Just opened up the coax cabling and find PT used orange "RG6/U 3Ghz" coax for the SAT hookup and black "Coleman Cable 92003 RG6 CM or CL2 or CATV" for the CABLE hookup.
What PT told me was:
To answer a previous question, we use RG6 for satellite, for cable TV, and for roof antenna.
Guess I assumed that meant they used the SAME cable for all coax. I didn't bring my Sat dish, etc on this brief trip so experimenting will have to wait until next trip.
Does anyone know coax specs well enough to know if this black coax would handle a sat signal?
Bob
Old 08-15-2012, 10:54 AM   #30
ironj's Avatar
fyi, the standard rg6 will not generally support the operating frequency of the incoming sat feed from the dish.....the reason why you have a cable and a sat output is because the dish operates on a higher bandwidth than cable...although i have used short runs of standard rg6 and it has worked...its not really made to handle it well...
you CAN however use the cable feed to distribute the coax output of your reciever if it has one, which is generally modulated to a specific tv channel....(ie, put your tv on channel 62 and revieve cable feed from your reviever box)...since that output is designed to work on the standard cable bandwidth...
so to answer your question, you "MIGHT" be able to get a sat signal through standard rg6....but i highly doubt it....and if you did it would prob not support all the channels or my have poor signal quality and reception issues...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
