Old 06-09-2014, 01:26 AM   #1
Cable to analog TV
Hi,
I have three TVs in the RV (2007 Forrest River Cardinal). Two of the TVs are digital and work fine on cable provided by the RV park.
One TV is an older analog TV. I do have a digital converter that brings in antennae signals just fine, but how can I watch cable TV on the analog TV? The digital box does not allow for cable settings nor does the TV.
thanks,
Jim
Genghis is offline   Reply With Quote
Old 06-09-2014, 06:56 AM   #2
bubbles's Avatar
As I remember it, the input to the converter box could be either, antenna or cable and it would be converted. So, if the input to the converter is the same as the other tv's (antenna/cable) I think it should work. If not somehow you need to have a splitter installed to route the same input to the converter that the other tv's are looking at (antenna/cable) or an "A"-"B" type coax switch installed that will select either antenna or cable input to the converter. Sometimes routing and interfacing the requrement is easier said than done. Been awhile dealing with a converter box for me so I could be wrong again..
Old 06-09-2014, 11:00 AM   #3
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
You will need a digital tuner box.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 06-09-2014, 11:21 AM   #4
Herk7769's Avatar
Bob is right on. You will need a digital to analog converter box with a QAM tuner. This is not a common converter as they are usually supplied by the cable company. The more common digital to analog ATSC (Over the Air - OTA) tuner is far easier to find.
http://www.amazon.com/Kworld-HDmi-Ex.../dp/B002RL8I2W
This unit will fix both your Cable and OTA problem with that TV.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-09-2014, 10:41 PM   #5
camaraderie's Avatar
Of course... you may be able to find an HD set for not much more $$ and without the complexity. Walmart has a 19" for $98 bucks... and a 30" for $169... maybe it is time to make the change.
camaraderie is offline   Reply With Quote
Old 06-10-2014, 06:39 AM   #6
Herk7769's Avatar
Well, then there is that...
Old 06-10-2014, 08:43 PM   #7
Thanks for the thoughts, helps make the decision a lot easier. thanks a lot,
Jim
